BT.com
Wishlist
Veho Muvi Full HD Mini Camcorder inc wireless remote & 4GB Memory
Delivery
Standard Due date unavailable
The latest addition to the popular MUVI micro camcorder range introduces the MUVI HD10 mini handsfree camcorder. The HD 10 captures handsfree high definition footage and snapshot using the 160 degree super wide angle lens and the sensa wireless remote control. The HD10 also includes a self timer, noise activation, touch panel, digital zoom and ships with a 4GB Micro SD card (upgradable to 32GB) and a 1400mah internal battery that will give 4hrs record time . As well as the rich technical specifications the MUVI also comes with a range of sports mounting clips and accessories that enables you to record in almost any situation.
Veho muvi HD10 - action camera
Action camera - 1080p - widescreen
Action Camera Type
Mountable
Memory Card Slot
microSD card
Sensor Resolution
5.0 MP
Lens System
F/2.5
Focus Adjustment
Automatic
Min Focus Distance
2.5 cm
Digital Zoom
3x
Display
LCD display - 1.5"
Supported Battery
1 x Li-ion rechargeable battery - 1400 mAh (included)
4.7 cm x 1.9 cm x 8 cm
81 g
Camcorder Sensor Resolution
5.0 MP
Widescreen Video Capture
Optical Sensor Type
CMOS
ISO (Max)
200
Digital Zoom
3x
Exposure & White Balance
Light Sensitivity
ISO 100, ISO 200
Lens System
F/2.5
Focus Adjustment
Automatic
Min Focus Distance
2.5 cm
Max View Angle
160 degree(s)
Additional Features
Additional Features
Audio recording, auto power save, USB charging, sound activated recording, touch panel control
Action Camera Features
Camera Type
Mountable
Display
1.5" LCD display
Display Form Factor
Built-in
Microphone
Microphone Operation Mode
Mono
Connector Type
USB
Spring clip, helmet mounting kit, radio remote control
Details
Memory / Storage
Memory Card Slot
microSD card
Supported Memory Cards
microSD Card, microSDHC Card
Included Memory Card
4 GB microSDHC
Video Capture
1920 x 1080 - 30 fps , 1280 x 720 - 30 fps
4.7 cm
1.9 cm
8 cm
81 g
Accessories
£11.72
Scroll to top
