BT.com
Wishlist
Veho Micro SD-USB Adapter/Card Reader
Delivery
Standard Due date unavailable
Veho VSD-003 Micro SD USB Card Reader
Whether you want to move your Veho Muvi videos to your PC or your music, photos or personal data between your mobile phone and your PC, it is fast and convenient with a Veho Mino Micro SD Card Reader.
Compatible with all micro SD and SDHC flash memory cards used in memory enabled mobile phones and PDAs, you can plug the Mino Micro SD Card reader into any USB 2.0 PC/Mac port and it will be immediatly recognised. Direct plug in means no card adapters and no software are required. The Veho Mino is so tiny and lightweight it can be carried with you wherever you go and you can ensure you are always able to transfer your data.
Product Features:
- Micro SD card reader compatible with Muvi and all micro SD cards including phone micro SD cards
- Turn your Micro SD card into a USB pen drive
- USB 2.0 Compliant
- Supports Micro SD/SDHC
- Bus Powered. No external AC power needed
- Supports Windows 98/ME/2000/XP/Vista
- Supports Mac OS 9.0 & above
Supported Formats
microSD
microSDHC
USB
Scroll to top
