BT.com
Wishlist
V7 Wireless Optical Mouse USB - Black
Delivery
Standard Due date unavailable
The ambidextrous compact wireless 2.4 GHz Plug and Play optical LED mouse has a premium finish for comfortable use. This high quality, space saving, 3 button mouse includes a built-in scroll wheel for quick navigation. The 1600 dpi high performance optical sensor provides smooth and precise cursor control on large high resolution displays. The smart power management "wake-up" feature extends battery life and is complemented by an on/off switch and low battery indicator. The self-storing wireless USB nano receiver makes this an excellent choice for the home, office or while traveling for business.
V7 MV3050 - mouse - 2.4 GHz - black
Mouse
Wireless - 2.4 GHz
5.8 cm x 9.5 cm x 3.4 cm
56.1 g
Wireless Receiver
USB wireless receiver
Movement Detection Technology
Optical
Buttons Qty
3
Movement Resolution
1600 dpi
Scrolling wheel, battery indicator, power saving automatic sleep function, on/off power switch, Nano wireless receiver
AAA type
Apple MacOS X 10.x or later, Microsoft Windows Vista / XP / 7 / 8
2 years warranty
Mouse
Wireless Receiver
5.8 cm
9.5 cm
3.4 cm
56.1 g
Input Device
Wireless
2.4 GHz
Max Operating Distance
Up to 6 m
Optical
Buttons Qty
3
Movement Resolution
1600 dpi
1 x USB 2.0 - 4 pin USB Type A
FCC, RoHS ; USB 2.0 Full-Speed
AAA type
Scroll to top
