BT.com
Wishlist
V7 Wireless Blue Trace Mouse - Navy Blue
Delivery
Standard Due date unavailable
Enjoy all day comfort with the full size 2.4 GHz wireless Blue Trace mouse that is Windows 8 optimized with two hot key buttons for charm menu and application switching. The 5 button mouse works on virtually any surface and includes a built-in scroll wheel for quick navigation. The 1600 dpi high performance optical LED sensor provides smooth and precise cursor control on large high resolution displays. This mouse is beautifully sculptured with a contoured shape, soft rubber grips, curved sides and broad palm area to reduce fatigue while enhancing the aesthetic appeal of your desktop. The smart power management "wake-up" feature extends battery life and is complemented by an on/off switch and low battery indicator. The self-storing wireless USB nano receiver makes this an excellent choice for the home, office or while traveling for business.
V7 MV5000 - mouse - black with blue
Mouse
Wireless
Black with blue
6.8 cm x 11 cm x 3.8 cm
71.1 g
Wireless Receiver
USB wireless receiver
Movement Detection Technology
Optical
Buttons Qty
5
Movement Resolution
1600 dpi
Scrolling wheel, Blue Trace Technology
Apple MacOS X 10.x or later, Microsoft Windows Vista / XP / 7 / 8
2 years warranty
Mouse
Wireless Receiver
6.8 cm
11 cm
3.8 cm
71.1 g
Black with blue
Input Device
Wireless
Optical
Buttons Qty
5
Movement Resolution
1600 dpi
1 x USB 2.0 - 4 pin USB Type A
Scroll to top
