BT.com
Wishlist
V7 Universal Projector Ceiling Mount 50LB
V7 Universal Projector Ceiling...
£72.37
23 in stock
£72.37
Add to wishlist
Delivery
Standard 3-5 working days
The PM1U50 is a universal projector mount designed to hold projectors that weigh up to 50lbs. Its clean looks and simple installation make it prefect for everything from Home Theaters to Commercial Installs. Finished is a satin black powder coat, the PM1U50 comes with a down pipe that has 'through pipe' cable management, a ceiling trim ring to give it a truly finished look, adjustable arms to fit most any projector, and a hot swap capability for bulb replacement. Tilt and Yaw are accomplished via a variable tension 'bicycle type' clip that requires no tools to adjust. The PM1U50 is the perfect mount for all of your Projector mount needs.
V7 PM1U50-1E - projector mount kit
Projector mount kit
Placing / Mounting
Ceiling mountable
40 cm x 40 cm x 13.462 cm
2.3586 kg
Projector mount kit
Placing / Mounting
Ceiling mountable
Flat Panel Mount Interface
100 x 100 mm
40 cm - 40 cm - 13.462 cm
2.3586 kg
Scroll to top
