BT.com
Wishlist
V7 Powerbank 17000mAh Dual Port
£39.19
More than 50 in stock
£39.19
Add to wishlist
Delivery
Standard 3-5 working days
This slim and stylish powerbank with aluminum finish is the perfect travel companion.
V7 Select Ultra-Slim PB17000P - power bank - Li-pol
Power bank
1.22 cm x 17.5 cm x 1.35 cm
538 g
Output Connector Type
USB (power only) - on cable: Micro-USB
5 V
Voltage Provided
5 V
Lithium polymer - 17000 mAh
1 year warranty
Power bank
1.22 cm
17.5 cm
1.35 cm
538 g
Enclosure Colour
Dark grey
5 V
Input Connectors
5 pin Micro-USB Type B (power only)
Input Connectors Qty
1
Voltage Provided
5 V
Output connectors
Total 2: 4 pin USB Type A (power only)
Power Provided
21 Watt
Detachable Cable Connector Type
Micro-USB Type B
Max Electric Current
4.2 A
Output Details
2 x 4 pin USB Type A (power only) - 5 V - 2.1 A
Smart IC chip, on/off button, LED display
Lithium polymer
17000 mAh
Recharge Time
12 hour(s)
Max Recharge Cycles
500
Micro-USB cable - 30 cm
FCC, RoHS
Limited warranty - 1 year
Scroll to top
