BT.com
Wishlist
V7 Mini Displayport to HDMI Adaptor (CBL-MH1WHT-5E)
V7 Mini Displayport to HDMI Adaptor...
£13.44
11 left in stock
£13.44
Add to wishlist
Delivery
Standard 1-3 working days
Express Delivered on Monday
Express Delivery
  • 00 h
  • 00 m
  • 00 s
The V7 Mini DisplayPort to HDMI adapter lets you connect a high definition monitor, projector, or LCD that uses a HDMI connector or cable to an Apple MacBook, MacBook Pro as well as other Apple products with a mini DisplayPort. The adapter allows you to view HD content from your Blue-ray players or a cable box on your Apple LED-backlit widescreen monitor. The V7 Mini Display Port to HDMI adapter supports high-resolution video and audio, allowing you to display HD content from external devices on the 27-inch iMac. Simple to use, this small form factor converter makes Mini DisplayPort backwards compatible with your existing HDMI display or projector. No software installation or drivers required providing a simple plug and play solution.
V7 video / audio adaptor - 17 cm
Cable
Video / audio adaptor
Length
17 cm
Connector
Mini DisplayPort - male
Connector (Second End)
HDMI - female
2 years warranty
Apple MacBook; MacBook Air; MacBook Pro
Cable Type
Length
17 cm
White
Connector
19 pin HDMI Type A - female
Apple MacBook , Apple MacBook Air , Apple MacBook Pro
Scroll to top
