BT.com
Wishlist
V7 Low-profile Wall Mount
£19.09
22 in stock
£19.09
Add to wishlist
Delivery
Standard 3-5 working days
The low profile wall mount connects directly to your wall to hold flat panel displays from 32" to 65". This high quality mount allows you to tilt the screen to obtain the optimal viewing angle. Installation is easy and precise with the built in bubble level. After installation, the unit remains securely in place with the built in locking screw.
V7 - wall mount (Low Profile Mount)
Wall mount (Low Profile Mount)
64.5 cm x 5.2 cm x 43 cm
2.22 kg
Recommended Use
LCD / plasma panel
Recommended Display Size
32"-65"
Flat Panel Mount Interface
100 x 100 mm, up to 600 x 400 mm
Max Load Weight
35 kg
5 years warranty
64.5 cm
5.2 cm
43 cm
2.22 kg
AV Furniture
Wall mount
Mounting Components
Tilt wall mount
Design
Low Profile Mount
Recommended Use
LCD / plasma panel
32"-65"
Max Load Weight
35 kg
Lockable, integrated bubble level
Limited warranty - 5 years
Scroll to top
