BT.com
Wishlist
V7 Low-profile Articualted Mount
£81.10
13 in stock
£81.10
Add to wishlist
Delivery
Standard 3-5 working days
The heavy duty low profile articulating mount connects directly to your wall and holds large screen flat panel displays from 32" to 65". This high quality mount uses dual cantilever arms that allow you to move the display left or right and toward or away from the wall. The cable management channel keeps video and power cables organized. The "H" truss mounting bracket allows you to screw directly to wall studs for a safe and secure connection.
V7 - wall mount (Low Profile Mount)
Wall mount (Low Profile Mount)
60 cm x 48.6 cm x 40 cm
Tilt
8.1 kg
Recommended Use
LCD / plasma panel
Recommended Display Size
32"-65"
Flat Panel Mount Interface
100 x 100 mm, up to 600 x 400 mm
Max Load Weight
45 kg
5 years warranty
60 cm
48.6 cm
40 cm
8.1 kg
AV Furniture
Wall mount
Mounting Components
Articulating wall mount
Design
Low Profile Mount
Recommended Use
LCD / plasma panel
Cable Management
Integrated cable management
32"-65"
Tilt
Max Load Weight
45 kg
Adjustable depth, swivel adjustment
Limited warranty - 5 years
Scroll to top
