BT.com
Wishlist
V7 Low-profile Articualted Mount
£24.26
More than 50 in stock
£24.26
Add to wishlist
Delivery
Standard 3-5 working days
The low profile articulating mount connects directly to your wall and holds flat panel displays from 10" to 32". This high quality mount allows you to move the display left or right and in or out from the wall. The cable management channel keeps video and power cables organized. The integrated level bubble help insure accurate leveling during installation.
V7 - wall mount (Low Profile Mount)
Wall mount (Low Profile Mount)
22.7 cm x 33 cm x 22.7 cm
Tilt
1.4 kg
Recommended Use
LCD display
Recommended Display Size
10"-32"
Flat Panel Mount Interface
75 x 75 mm, up to 200 x 200 mm
Max Load Weight
25 kg
5 years warranty
22.7 cm
33 cm
22.7 cm
1.4 kg
AV Furniture
Wall mount
Mounting Components
Articulating wall mount
Design
Low Profile Mount
Recommended Use
LCD display
Cable Management
Integrated cable management
10"-32"
Tilt
Max Load Weight
25 kg
Adjustable depth, swivel adjustment, lateral shift
Limited warranty - 5 years
Scroll to top
