Click to visit BT.com
BT.com
Wishlist
V7 Elite Webcam 2000 USB/MIC
2.0*
Quicklinx: 8KLGWS00
Mfr#: CS2021S-1E
Compatibility: PC
£16.26
Take instant communication to level with the V7 Elite Webcam. Featuring a true 2.0 megapixel sensor, auto focus, and a built-in microphone, the Elite offers HD video capture at up to 1600 x 1200 resolution. This V7 webcam offers vivid live images and sound, making it an ideal solution for virtual face-to-face meetings with important business and personal contacts. The V7 Elite Webcam has a universal clip/stand for easy mounting on desks or flat panel monitors.
The V7 Elite Webcam's true 2.0 megapixel sensor with auto focus allows for HD video capture up to 1600 x 1200 pixels at 30 FPS transmission speed, as well as 16-megapixel photos.
The universal clip stand allows for versatile positioning to accommodate all types of PC setups. There is a standalone option as well to make it easier to use the Elite with portable computers such as laptops.
V7 Elite Webcam CS2021S - web camera
Web camera
Audio
Yes : built-in microphone
7 cm x 2.5 cm x 2 cm
74 g
Wired
Camera
Max Resolution
1600 x 1200
Frame Rate
30 frames per second
Optical Sensor Type
2 MP
Focus Adjustment
Automatic
USB 2.0
Web camera
Audio Support
Wired
7 cm
2.5 cm
2 cm
74 g
Camera
Max Digital Video Resolution
1600 x 1200
Image Sensor
2 MP
Lens Construction
Focus Adjustment
Automatic
Computer Interface
USB 2.0
1 x USB 2.0
V7 Elite Webcam 2000 USB/MIC Bundle deal on V7 Elite Webcam 2000 USB/MIC
Including:
Corsair Flash Voyager Slider - 32GB - USB 3.0 Corsair Flash Voyager Slider - 32GB - USB 3.0 worth £14.98 | while stocks last
£26.25
saving £4.99
Customer reviews
Write a review for the V7 Elite Webcam 2000 USB/MIC here!
Don't buy
Reviewed by John Dingle. Review Posted 14/08/2014
This was my first webcam.
The cable to the microphone socket had to take a route across my DVD drive. Basicly the 1.5m cable was to short to reach the top of my monitor.
The User manual provided incorrectly described to Software user interface.
The user manual does not tell you how to start a recording of the signal and then stop it again.
The camera works, but the mounting is terrible, looking like it was designed for an RGB monitor top.
I'll never buy this brand again. I sent it back.
  • Overall 2*
  • Ease of use 1*
  • Value for money 4*
The opinions expressed in this reviews section are those of our customers and not of BT Shop. Nothing contained herein amends BT Shop’s terms and conditions.
Compatibility: PC
Brand: V7
Price Range Inc VAT: 0 - 50
