BT.com
Wishlist
V7 Edge Backpack 17.3" - Black/Blue
Delivery
Standard Due date unavailable
The sleek V7 Edge laptop backpack holds your 17.3-inch notebook and essentials so that you can be productive while you're on the go. The V7 Edge laptop backpack's lightweight design doesn't weigh you down, and its ergonomic design features air mesh material that prevents moisture to keep you comfortable until you arrive at your next destination.
One main zippered accessory workstation organizes your business cards, pens, keys, power cord, smartphone and other productivity tools in keeping your essential items within easy reach. A front panel complements the main workstation to provide quick access to your wallet, airplane tickets, passport, MP3 player, and other frequently used items.
Designed for comfort and storage, this backpack has a place for everything. The V7 backpack has all the key features everyone should consider in purchasing, from its separate, padded laptop compartment that fits most laptops with a 17.3-inch screen, to a main compartment for file storage including soft organizational sleeves, to the organized workstation that includes key clip, four pen loops, two netted accessory pockets, mobile phone pocket, business card holder and separate file sections. The V7 Edge backpack also features two elastic water bottle pockets.
Ergonomically, the V7 backpack has padded shoulder straps and cushioned handles allowing for maximum comfort and weight distribution, as well as two side water-bottle pockets.
V7 Edge CBD2-BLU-9E - notebook carrying backpack
Notebook carrying backpack
Black with blue accents
Product Material
600D Gucci polyester
34.2 cm x 13.9 cm x 45.9 cm
820 g
Notebook Compatibility
17.3"
Moisture-proof, padded shoulder strap
Carrying Strap
Hand grip, shoulder carrying straps
Product Material
34.2 cm
13.9 cm
45.9 cm
820 g
17.3"
Notebook Compatibility Dimensions
41.6 cm x 27.5 cm x 3.8 cm
Additional Compartments
Mobile phone, umbrellas, bottle, business cards
Carrying Strap
Scroll to top
