BT.com
Wishlist
V7 Earbuds with inline Microphone - Green
Delivery
Standard Due date unavailable
The Stereo Earbuds with Inline Mic provide comfort and high-fidelity sound quality with soft-bass, ideal for use with iPads, iPhones, MP3 players and any electronic device that supports a 3.5mm audio jack. The Earbuds feature a space-saving right-angle 3.5 mm jack, and soft rubber caps that ensure a comfortable fit. The inline mic is great for phone calls, and there is a built in play/pause, call answer/call end function so you can you use the phone and listen to music without missing a beat.
V7 HA110 - earphones with mic
Earphones - wired - 3.5 mm jack
Recommended Use
Portable electronics
Green
Headphones Form Factor
In-ear
Wired
Sound Output Mode
Stereo
Impedance
32 Ohm
Microphone
On-cable
Controls
Answer/end, play/pause
2 years warranty
Earphones - 3.5 mm jack
2.1 cm
1.8 cm
1.2 cm
12 g
Green
Recommended Use
Headphones
In-ear
Wired
Available Microphone
Sound Output Mode
Stereo
Impedance
32 Ohm
Microphone
On-cable
Remote Control
Controls
Connector Type
Headphones (mini-phone stereo 3.5 mm 4-pole)
Headphones cable - 1.2 m
FCC, RoHS
Scroll to top
