BT.com
Wishlist
V7 Bluetooth Water Resistant Speaker -  Black
V7 Bluetooth Water Resistant...
£19.99
More than 50 in stock
£19.99
Add to wishlist
Delivery
Standard 3-5 working days
Now you can take your music anywhere you go with the V7 Water-resistant and rugged Bluetooth wireless Speaker. It's the ideal companion for beach, hot tub pool party, picnic or simply just singing in the shower. It's so versatile that you can even use the keychain hook to attach to your backpack while you hike. Built-in rechargeable lithium ion battery keeps the music flowing for 2 - 3 hours. Bluetooth technology has a wireless range of 30 ft and makes connection to your mobile device such as Apple iPad, iPhone, iPod touch, Android devices and more simple.
V7 SP5100 - speaker - for portable use - wireless
Speaker - portable
Protection
Waterproof
7.37 cm x 8.38 cm x 11.4 cm
195 g
Speaker Type
Active
Audio Amplifier
Integrated
Connectivity Interfaces
Bluetooth
Power Options
USB charging
Speaker battery - rechargeable - Lithium Ion
Speaker - for portable use
Protection
Waterproof
7.37 cm
8.38 cm
11.4 cm
195 g
Enclosure Colour
Speaker System
Speaker Type
Active
Audio Amplifier
Integrated
Bluetooth
Transmission Range
9.75 m
Controls
Power on/off, volume, call answer, activate Bluetooth
Connector Type
Audio line-in ( mini-phone stereo 3.5 mm )
Options
USB charging
Run Time (Up To)
3 hour(s)
Scroll to top
