BT.com
Wishlist
V7 Bluetooth Portable Speaker - White
Delivery
Standard Due date unavailable
Listen to your favorite songs from your Bluetooth enabled device through the crystal clear V7 Bluetooth wireless speaker. You will enjoy its 33 feet range, and hands-free speakerphone function allowing you to answer phone calls from your Bluetooth enabled mobile phone. The powerful 2.5 W speakers have a built-in passive radiator woofer for deep base. The USB rechargeable built-in battery provides longer uninterrupted sound while you're on the go.
V7 SP6000 - speaker - for portable use - wireless
Speaker - for portable use
Speaker Type
Active
Nominal Output Power
5 Watt
Frequency Response
80 - 20000 Hz
Amplifier
Integrated
Bluetooth, NFC
Speaker Details
Speaker - stereo - 2 x 2.5 Watt - 80 - 20000 Hz - active
White
Power Options
USB charging, USB powered
Speaker battery rechargeable - lithium polymer
14 cm x 6.6 cm x 9.3 cm
350 g
2 years warranty
Hands-Free Function
Enclosure Colour
White
Speaker System
Speaker Type
Active
5 Watt
Frequency Response
80 - 20000 Hz
Amplifier
Integrated
Bluetooth 3.0, Near Field Communication (NFC)
Bluetooth Profiles
Hands-Free Profile (HFP), Advanced Audio Distribution Profile (A2DP), Audio/Video Remote Control Profile (AVRCP)
Transmission Range
10 m
Controls
Power on/off, volume, call answer
Speaker System Details
Speaker Details
Driver Details
Speaker: 2 x full-range driver , Speaker: Passive Radiator
Connector Type
Audio line-in (mini-phone stereo 3.5 mm) , DC power output (4 pin USB Type A (power only))
Micro-USB cable
Power Source
Options
Rechargeable - lithium polymer
3600 mAh
Run Time (Up To)
16 hour(s)
14 cm
6.6 cm
9.3 cm
350 g
Scroll to top
