BT.com
Wishlist
V7 Bluetooth Portable Speaker - White
Delivery
Standard Due date unavailable
Do you often listen to music or play online games on your computer? But have you long been disappointed by the sound from your PC speakers? With V7 PC speakers you'll have full sound in your living room. The elegant USB speakers and sound system with subwoofer are also real eye-catchers thanks to their stylish designs.
Listen to your favorite songs from your Bluetooth enabled device through the crystal clear V7 Bluetooth wireless speaker. You will enjoy its 33 foot range, and hands-free speakerphone function allowing you to answer phone calls from your Bluetooth enabled mobile phone. Designed with a powerful 2 Watt wireless speaker, a built-in sub-woofer and bass vibration function. The USB rechargeable built-in battery, charges fully in 2-3 hours to provide up to 4 hours of uninterrupted sound while you\re on the go.
V7 - speaker - for portable use - wireless
Speaker - portable
6.35 cm x 6.35 cm x 6.35 cm
200 g
Speaker Type
Active
Nominal Output Power
2 Watt
Frequency Response
100 - 16000 Hz
Audio Amplifier
Integrated
Connectivity Interfaces
Bluetooth
Speaker System Details
1 x portable speaker 2 Watt - 100 - 16000 Hz
White
Power Options
USB charging
Speaker battery rechargeable - lithium polymer
2 years warranty
Speaker - for portable use
Hands-Free Function
6.35 cm
6.35 cm
6.35 cm
200 g
Enclosure Colour
White
Enclosure Material
Silicone
Speaker System
Speaker Type
Active
2 Watt
Frequency Response
100 - 16000 Hz
Audio Amplifier
Integrated
Bluetooth 2.0
Bluetooth Profiles
Hands Free Profile (HFP)
Transmission Range
10 m
Controls
Power on/off, volume
Additional Features
Surface vibration technology
Speakers Included
1 x portable speaker - 2 Watt - 100 - 16000 Hz
Connector Type
Audio line-in (mini-phone stereo 3.5 mm)
Power Source
Options
USB charging
400 mAh
Run Time (Up To)
4 hour(s)
Scroll to top
