BT.com
Wishlist
V7 8GB USB Flash Drive - Black
Delivery
Standard Due date unavailable
The V7 USB 2.0 flash drive with retractable connector features an easy to use, slide-out design that will keep your USB connector free of dirt and dust, keeping your data safe. Store loads of files, and take them with you wherever you go, with a range of size options to choose from.
V7 VU28GDR-BLK-3E - USB flash drive - 8 GB
USB flash drive
Interface Type
USB 2.0
Storage Capacity
8 GB
Enclosure Colour
Apple MacOS 9.x or later, Linux Kernel 2.4 or later, Microsoft Windows 98/2000/XP/Vista/7/8
5 years warranty
USB flash drive
Storage Capacity
8 GB
Enclosure Colour
Compatibility
Non-specific
Read Rate
Up to 10 MB/s
Write Rate
Up to 3 MB/s
Interface Type
USB 2.0
Dustproof, retractable connector, dirtproof
Plug and Play, FCC, RoHS, WEEE
Limited warranty - 5 years
10 mm
20 mm
56 mm
14 g
Scroll to top
