BT.com
Wishlist
V7 7 Port USB Hub (HU720-3EP)
£10.22
Hurry, only 2 left in stock!
£10.22
Add to wishlist
Delivery
Standard 1-3 working days
Express Delivered on Monday
Express Delivery
  • 00 h
  • 00 m
  • 00 s
V7 hub works with all types of USB compliant devices including digital cameras, video cameras, scanners, joysticks, and more. With Plug-and-Play, hot swapping features, the hub allows attaching and removing of USB devices without reconfiguring settings or turning the computer system off. The high speed hub allows multiple high-performance USB 2.0 peripherals to connect to the PC for effective and efficient productivity.
V7 HU720-3EP - hub - 7 ports - desktop
Hub - 7 ports
Enclosure Type
Desktop
Subtype
USB
Ports
7 x USB 2.0
USB 1.1, USB 2.0
6.9 cm x 6.9 cm x 2.4 cm
55 g
Apple MacOS X / MacOS 9.1, Microsoft Windows 98/2000/XP/Vista/7
Hub - 7 ports
Enclosure Type
Desktop
Subtype
USB
Ports
7 x USB 2.0
USB 1.1, USB 2.0
7 x USB 2.0 - Type A , 1 x USB 2.0 - Type A
1 x USB cable
Plug and Play, C-Tick, FCC, RoHS, WEEE
6.9 cm
6.9 cm
2.4 cm
55 g
Scroll to top
