BT.com
Wishlist
V7 23.6" Privacy Filter
£64.82
22 in stock
£64.82
Add to wishlist
Delivery
Standard 3-5 working days
V7 Privacy Filters are excellent for open, high-traffic environments or wherever on-screen data needs to be kept private. Screen data is visible only to persons directly in front of the monitor without blurring or distortion. The filter darkens on-screen information when viewed from the side.
The high-gloss finish sharpens contrast and helps to protect fragile LCD screens from scratches and damage. V7 Privacy Filters are easy to attach and remove, and can be left in place even when your notebook computer is closed.
V7 Privacy Filter - display privacy filter - 23.6" wide
Display privacy filter
Display Screen Size Compatibility
23.6" wide
52.1 cm x 0.025 cm x 29.2 cm
23.6" wide
52.1 cm - 0.025 cm - 29.2 cm
Monitor Filter
Scratch Resistant
Scroll to top
