BT.com
Wishlist
V7 23.6" 1920x1080 5MS VGA DVI-D LED Monitor with Speakers
Delivery
Standard Due date unavailable
The V7 24" Class LED monitor is designed with style, high screen performance and features for home, work and everything in between. The V7 LED widescreen monitor utilizes a low-power LED backlight contributing to a reduced environmental footprint while displaying sharp, dazzling images in Full HD 1920x1080p resolution.
With the HDMI input, you can connect to your PC, game console, or DVD player, providing the perfect multipurpose display.
The high performance specifications includes 30000000:1 contrast ratio, 200 nits brightness, and 5ms response time. This large widescreen screen LED monitor is a great value and looks sharp on every desktop. With both VGA and HDMI inputs, you are sure to enjoy the highest resolution possible.
The V7 LED monitor comes fully equipped with two built-in on-board speakers for the complete audio-video experience.
V7 L23600WHS-9K - LED monitor - Full HD (1080p) - 24"
LED-backlit LCD monitor - 24"
Energy Class
Class A+
Energy Consumption per Year
27 kWh
Power Consumption (On mode)
18 W
Aspect Ratio
Widescreen - 16:9
Native Resolution
Full HD (1080p) 1920 x 1080
Brightness
200 cd/m²
Contrast Ratio
30000000:1 (dynamic)
Response Time
5 ms
Colour Support
16.7 million colours
Input Connectors
HDMI, VGA
Speakers
Integrated
Display Position Adjustments
Tilt
55.9 cm x 18 cm x 42.2 cm
4.2 kg
United Kingdom
FCC, RoHS, WEEE
3 years warranty
Display Type
Energy Class
Class A+
27 kWh
18 W
Diagonal Size
24"
Viewable Size
23.6"
Aspect Ratio
Widescreen - 16:9
Native Resolution
Brightness
200 cd/m²
Contrast Ratio
Colour Support
Response Time
5 ms
Vertical Refresh Rate
55 - 75 Hz
Horizontal Refresh Rate
30 - 80 kHz
Horizontal Viewing Angle
170
Vertical Viewing Angle
160
Backlight Technology
LED backlight
Slim bezel design
55.9 cm x 18 cm x 42.2 cm - with stand
4.2 kg
Audio
Speakers - integrated
Output Power / Channel
2 Watt
VGA (HD-15) , HDMI , Audio line-in
Mechanical
Tilt
Tilt Angle
-5/+15
Flat Panel Mount Interface
75 x 75 mm
Stand
1 x VGA cable , 1 x power cable
FCC, RoHS, WEEE
United Kingdom
AC 100/240 V
On / Off Switch
Apple MacOS X, Microsoft Windows Vista, Microsoft Windows XP / 7 / 8 or later
Dimensions & Weight Details
Without stand - width: 55.9 cm - depth: 4.7 cm - height: 31.5 cm
Limited warranty - 3 years
Scroll to top
