BT.com
Wishlist
V7 21.5" 1920x1080 5MS VGA DVI-D LED Monitor with Speakers
Clearance
Last Few Remaining
Price Drop
Price Drop!
Delivery
Standard Due date unavailable
The V7 Full HD LED monitor, provides superior image quality with vivid colors and life-like images. V7 LED backlight technology saves up to 40% energy and yields blacker blacks, pure white and more clearly defined grays for a vivid picture making it the perfect choice for home or office use. With vivid colors with a 1920x1080 Full HD resolution, 16:09 aspect ratio, 1,000,000:1 contrast ratio, 200 nits brightness, and many customizable settings to fit your needs. The L21500WDS provides for more desk space with its small desktop footprint, and looks great with a glossy bezel. The widescreen monitor is easily wall mountable and with both a VGA and DVI-D output you are sure to enjoy the highest resolution possible. The V7 LED monitor comes fully equipped with built-in on-board speakers for the complete audio- video experience.
V7 L21500WDS-9K - LED monitor - 22"
LED-backlit LCD monitor - 22"
Energy Class
Class A+
Aspect Ratio
Widescreen - 16:9
Native Resolution
Full HD 1920 x 1080
Brightness
200 cd/m²
Contrast Ratio
1000000:1 (dynamic)
Response Time
5 ms
Colour Support
16.7 million colours
Input Connectors
DVI, VGA
Display Position Adjustments
Tilt
Glossy black
52.4 cm x 18 cm x 36.6 cm
3.29 kg
English / United Kingdom
FCC, RoHS, WEEE
3 years warranty
Display Type
Energy Class
Class A+
Diagonal Size
22"
Viewable Size
21.5"
Aspect Ratio
Widescreen - 16:9
Native Resolution
Full HD 1920 x 1080
Brightness
200 cd/m²
Contrast Ratio
1000000:1 (dynamic)
Colour Support
Response Time
5 ms
Vertical Refresh Rate
55 - 75 Hz
Horizontal Refresh Rate
30 - 80 kHz
Horizontal Viewing Angle
170
Vertical Viewing Angle
160
Backlight Technology
LED backlight
Slim bezel design
Glossy black
52.4 cm x 18 cm x 36.6 cm - with stand
3.29 kg
Audio
Speakers - stereo
Output Power / Channel
2 Watt
DVI-D , VGA (HD-15)
Mechanical
Tilt
Tilt Angle
-5/+15
Flat Panel Mount Interface
100 x 100 mm
VESA interface support
1 x VGA cable
FCC, RoHS, WEEE
AC 120/230 V
Apple MacOS X, Microsoft Windows Vista / XP / 7 / 8
Dimensions & Weight Details
With stand - width: 52.4 cm - depth: 18 cm - height: 36.6 cm - weight: 3.29 kg , Without stand - width: 52.4 cm - depth: 4.7 cm - height: 29 cm
Limited warranty - 3 years
Scroll to top
