BT.com
Wishlist
V7 10000mah Powerbank
Delivery
Standard Due date unavailable
Keep your devices charged up while on the go with the High-Capacity 10,000 mAh Dual Port Powerbank from V7. With 2 ports each producing 2.1 A - the powerbank delivers a total of 4.2 A output power. The rubberized, non-slip outer coating makes it great for traveling, and the built in Smart IC chip delivers the optimum charge efficiency based on device. It features an LED charge indicator so you know at a glance how much power you have remaining.
V7 power bank - Li-Ion
Power bank
7.5 cm x 10.9 cm x 2.2 cm
227 g
Output Connector Type
USB (power only)
5 V
Voltage Provided
5 V
Lithium Ion - 10000 mAh
1 year warranty
Power bank
7.5 cm
10.9 cm
2.2 cm
227 g
Enclosure Colour
5 V
Input Connectors
5 pin Micro-USB Type B (power only)
Voltage Provided
5 V
Output connectors
Total 2 : 4 pin USB Type A (power only)
Max Electric Current
2.1 A
LED indicator, rubberized, Smart IC chip
Lithium Ion
10000 mAh
Recharge Time
10 hour(s)
Max Recharge Cycles
500
USB cable
FCC, RoHS
Limited warranty - 1 year
Scroll to top
