BT.com
Wishlist
USRobotics 56K USB Softmodem
£34.30
£34.30
Add to wishlist
Delivery
Standard Due date unavailable
The USRobotics 56K USB Softmodem delivers the performance and reliability USRobotics is known for in a compact, cost effective form factor. Broadly compatible with Windows including 64-bit and server systems, the modem uses the CPU of the host computer for high compression throughput due to direct parallel access. Features include ring detection and qualification - eliminating unintended wake-on-ring events due to activity on the phone line other than ringing, as well as handling pulse dial control to eliminate system timing dependencies common with soft modems. The USRobotics USB Softmodem is fully compatible with V.92 and lower rates, making it ideal for compact POS solutions that only require V.34.
USRobotics 56K USB Softmodem - fax / modem
Fax / modem - USB
External
Max Transfer Rate
56 Kbps
Protocols & Specifications
ITU V.21, ITU V.29, ITU V.32, ITU V.32bis, ITU V.34, ITU V.90, ITU V.17, ITU V.27ter, ITU V.92
Error Correction Protocol
ITU V.42
Data Compression Protocol
MNP-5, ITU V.42bis, ITU V.44
Microsoft Windows Vista (32/64 bits), Microsoft Windows Embedded POSReady, Microsoft Windows 7 (32/64 bits), Microsoft Windows XP (32/64 bits), Microsoft Windows Server 2008 (32/64-bits), Microsoft Windows Server 2003 (32/64-bits), Microsoft Windows Home Server 2011, Microsoft Windows Server 2012, Windows 8 (32/64 bits)
7.8 cm x 3 cm x 2.1 cm
45 g
1 year warranty
Fax / modem
External
Modem
Bus
USB
Wired
Max Transfer Rate
56 Kbps
56K Technology
V.90, V.92
ITU V.42
USB powered
1 x phone line - RJ-11 , 1 x USB - Type A
1 x phone cable
Plug and Play, UL, cUL, IC, FCC, RoHS
Limited warranty - 1 year
7.8 cm
3 cm
2.1 cm
45 g
50 °C
20 - 80% (non-condensing)
Scroll to top
