BT.com
Wishlist
Unicol PZW3 Compact Tilting Wall Bracket For Screens 32-57"
Unicol PZW3 Compact Tilting Wall...
£199.35
£199.35
Add to wishlist
Delivery
Standard Due date unavailable
Imagine you could reach out and with a light touch, tilt your display anywhere through its range to suit your precise viewing angle. The ease of this is possible thanks to the patented POZIMOUNT tilt counterbalance mechanism. The tilt angle you choose is reliably set or can be changed whenever necessary. POZIMOUNT units can be direct wall fixed or used with any of the ceiling kits, swing-arm wall units or stands and trolleys.
Unicol POZIMOUNT PZW3 - wall mount
Wall mount
Adjustable Width
20-45 cm
Adjustable Height
20-41 cm
Recommended Use
LCD / plasma panel
Recommended Display Size
32"-57"
Flat Panel Mount Interface
200 x 200 mm, 400 x 300 mm, 400 x 200 mm, 400 x 400 mm, 300 x 300 mm
Max Mounting Pattern Size
540 x 440 mm
Max Load Weight
60 kg
Adjustable Width
20-45 cm
Adjustable Height
20-41 cm
Image Colour Disclaimer
The displayed product image may be a different colour
AV Furniture
Wall mount
Mounting Components
Tilt wall mount
Recommended Use
LCD / plasma panel
540 x 440 mm
32"-57"
Max Load Weight
60 kg
Adjustable height, adjustable width
Scroll to top
