BT.com
Wishlist
Ubiquiti UniFi Video Camera Dome - 3 Pack
Delivery
Standard Due date unavailable
The UniFi Video Camera is designed for use indoors or outdoors under an overhang. The camera has infrared LEDs with automatic IR cut filter. Accessible from a web browser, the UniFi video interface was designed to be easy to use yet packed with advanced features. The UniFi video interface is incredibly intuitive and loaded with powerful features such as detailed statistical reporting, multiple views, versatile camera settings, advanced analytics, and customizable event recordings.
Ubiquiti UniFi UVC-DOME - network surveillance camera
Network surveillance camera - fixed dome
Packaged Quantity
3 (specifications are for single item)
Audio
Yes: built-in microphone
Camera Mount Type
Ceiling mount
9.6 cm x 9.6 cm x 11.1 cm
178 g
Wired
Camera
Colour - Day&Night
Max Resolution
1280 x 720
Frame Rate
30 frames per second
Video Modes
720p
Optical Sensor Type
CMOS - 1/4"
Focal Length Control
Fixed focal
Focal Length
1.96 mm
Lens Iris
F/2.0
Ethernet 10Base-T/100Base-TX
Voltage
PoE
Sharpness control, saturation control, brightness control, Power over Ethernet, contrast control, microSD card slot, infrared cut filter, noise reduction
1 year warranty
Environmental Parameters (operating)
0 °C - 40 °C; 20 - 90% (non-condensing) relative humidity
Packaged Quantity
Audio Support
Camera Mount Type
Ceiling mount
Wired
9.6 cm
9.6 cm
11.1 cm
178 g
Camera
Colour - Day&Night - fixed dome
Digital Video Format
H.264
Max Digital Video Resolution
1280 x 720
Video Modes
720p
Digital Video Capture Resolution
1280 x 720
Frame Rate
RAM
256 MB
Image Sensor
CMOS 1/4"
Lens Construction
Fixed focal
Focal Length
1.96 mm
Lens Iris
F/2.0
Horizontal Field of View (degree)
88.8
Vertical Field of View (degree)
63
Network Interface
Ports
LAN/power - RJ-45
IC, FCC
Power Requirements
PoE
4 Watt
Limited warranty - 1 year
Relative Humidity (operating)
Scroll to top
