BT.com
Wishlist
Ubiquiti UniFi UVC-G3-DOME Network Surveillance Camera
Ubiquiti UniFi UVC-G3-DOME Network...
£161.73
£161.73
Add to wishlist
Delivery
Standard Due date unavailable
The UniFi Video Camera is designed for use indoors or outdoors under an overhang. The camera has infrared LEDs with automatic IR cut filter. Accessible from a web browser, the UniFi video interface was designed to be easy to use yet packed with advanced features. The UniFi video interface is incredibly intuitive and loaded with powerful features such as detailed statistical reporting, multiple views, versatile camera settings, advanced analytics, and customizable event recordings.
Ubiquiti UniFi UVC-G3-DOME - network surveillance camera
Network surveillance camera - fixed dome - outdoor
Audio
Yes: built-in microphone
Camera Mount Type
Wall mount, ceiling mount
13.2 cm x 6 cm x 13.2 cm
260 g
Wired
Camera
Colour - Day&Night
Max Resolution
1920 x 1080
Frame Rate (max)
30 frames per second
Optical Sensor Type
1/3" - 4 MP
Focal Length
2.8 mm
Lens Iris
F/2.0
Ethernet 10Base-T/100Base-TX
Voltage
PoE
Sharpness control, saturation control, brightness control, Power over Ethernet, contrast control, infrared cut filter, reset button, High Dynamic Range (HDR), noise reduction
Environmental Parameters (operating)
-30 °C - 70 °C; 20 - 90% (non-condensing) relative humidity
Audio Support
Camera Mount Type
Wired
13.2 cm
6 cm
13.2 cm
260 g
Camera
Colour - Day&Night - fixed dome - outdoor
Digital Video Format
H.264
Max Digital Video Resolution
1920 x 1080
Infrared LEDs
Digital Video Capture Resolution
1920 x 1080
Frame Rate (max)
RAM
512 MB
Image Sensor
4 MP 1/3"
Lens Construction
Focal Length
2.8 mm
Lens Iris
F/2.0
Network Interface
Ports
LAN/power
Power Requirements
PoE
4 Watt
Ubuntu 12.04, Ubuntu 14.04, Debian Linux 7.0, Microsoft Windows 7 / 8 / 10 (64 bits)
System Requirements Details
1.86 GHz - RAM 2 GB
-30 °C
70 °C
Relative Humidity (operating)
Scroll to top
