BT.com
Wishlist
Ubiquiti UniFi Switch 48 port 750W
£1,047.74
£1,047.74
Add to wishlist
Delivery
Standard Due date unavailable
Available with 48 RJ45 Gigabit ports, the UniFi Switch delivers robust performance, PoE+ support, and intelligent switching for growing networks.
Ubiquiti UniFi Switch US-48-750W - switch - 48 ports - Managed - rack-mountable
Switch - 48 ports - Managed
Enclosure Type
Rack-mountable 1U
Subtype
Gigabit Ethernet
Ports
48 x 10/100/1000 (PoE+) + 2 x 10 Gigabit SFP+ + 2 x Gigabit SFP
Power Over Ethernet (PoE)
PoE+
Performance
Non-blocking switching capacity: 70 Gbps , Switching capacity: 140 Gbps , Forwarding performance: 104.16 Mpps
Remote Management Protocol
HTTP
Non blocking ports
IEEE 802.3af, IEEE 802.3at
AC 120/230 V (50 - 60 Hz)
48.504 cm x 34.76 cm x 4.445 cm
5.3 kg
Enclosure Type
Rack-mountable 1U
Subtype
Gigabit Ethernet
Ports
PoE+
Performance
HTTP
Non blocking ports
Status Indicators
Port transmission speed, PoE, link/activity
48 x 1000Base-T RJ-45 PoE+ - 34.2 W , 2 x 1000Base-X SFP , 2 x 10GBase-X SFP+ , 1 x console RJ-45
Internal power supply
Power Provided
750 Watt
IC, FCC, RoHS, WEEE, ETSI 300 019
48.504 cm
34.76 cm
4.445 cm
5.3 kg
-5 °C
5 - 95% (non-condensing)
Scroll to top
