BT.com
Wishlist
Trust 5.1 Surround Soundcard SC-5100
Delivery
Standard Due date unavailable
Marketing description is not available.
Trust SC-5100 - sound card
Sound card
Enclosure Type
Internal
Interface Type
PCI
Sound Output Mode
5.1 channel surround
DAC Resolution
16-bit
Sample Rate
48 kHz (max)
Microsoft Windows 98 Second Edition, Microsoft Windows 2000, Microsoft Windows Millennium Edition, Microsoft Windows XP
2 years warranty
Sound card
Internal
Interface Type
PCI
Audio Output
Sound Output Mode
DAC Resolution
16-bit
Sample Rate
48 kHz (max)
MPU-401, EAX, A3D, DirectX
1 x microphone - mini-phone 3.5 mm , 1 x speakers (center/subwoofer)/audio line-in - mini-phone stereo 3.5 mm , 1 x audio line-out/headphones - mini-phone stereo 3.5 mm , 1 x speakers (rear) - mini-phone stereo 3.5 mm , 1 x MIDI - 15 pin D-Sub (DB-15)
Plug and Play
Additional Requirements
CD-ROM, speakers
System Requirements Details
Pentium II - 366 MHz - RAM 32 MB - HD 50 MB
Customer reviews
Write review The opinions expressed in this reviews section are those of our customers and not of BT Shop. Nothing contained herein amends BT Shop’s terms and conditions.
5* Cant fault it!
Reviewed by Haydn on 10/02/2012
Easy to set up, plug in, install drivers and go :D Improved my sound noticeably before sound wasn't very noticeable from 2 of my speakers but now their perfect :D
5* Excellent
Reviewed by Anonymous on 03/08/2007
Bought this in a local shop easy to set up and has never failed me. COME ON, HOW CAN YOU WRITE A BAD REVIEW ABOUT IT WHEN YOU GET IT FOR UNDER £10!?!?
5* Great soundcard for £10!
Reviewed by Kenny on 03/02/2008
For £10 this card is a bargain as it has excellent sound quality, much better than onboard sound (make sure to disable any onboard sound on your motherboards). The 5.1 surround is great too as it works fine for DVDs and Games. It is also compatible with Linux too as I fired up Fedora 8 and it worked no problems.
Again this is a great card for the money, well recommended!
5* Works for me!
Reviewed by Julian on 23/01/2008
Bought this card a while ago to replace the defunct sound on my mobo. Works fine with my Windows XP Home, no problems at all.
1* Soundcard issues
Reviewed by Anonymous on 26/07/2007
Installed the card and computer would take many minutes just to boot-up or would get stuck in a cycle of re-booting itself without loading into windows Xp at all. All in all a poor buy and one I cannot recommend.
1* Doesn't fit!
Reviewed by Anonymous on 30/03/2008
Needed a cheap audio card to fit into an HP Proliant ML110 G4 server. Unfortunately it won't physically fit due to a lack of a 3.3V key slot.
1* Doesn't work
Reviewed by Anonymous on 21/03/2012
It doesn't work on my system. Apparently i need to plug it into another slot to make it work but there are none available. So if you're buying this card try and make sure you have more than one slot available. Easily the biggest regret of the week was purchasing this card
Scroll to top
