Click to visit BT.com
BT.com
Wishlist
Tritton Trigger Stereo Gaming Headset for Xbox 360
Quicklinx: 8LYJWS00
Mfr#: TRI476760M02/02/1
Trigger Stereo Headset
TRITTON's officially licensed Trigger Stereo Headset delivers a comfortable, high-quality audio experience for Xbox 360 gaming. Providing the ability to adjust your chat volume and voice volume separately and on-the-fly, the Trigger is the ideal plug-and-play USB headset for all your Xbox 360 gaming needs.
Separate Game and Voice Volume Controls
If the chatter from your opponent gets distracting and starts to hinder your online gameplay experience, just turn a dial on the in-line audio controller (A) to tune them out. Game volume (B) can also be adjusted on-the-fly so you can drown out your foe's voice but still hear stealthy in-game footsteps creeping up behind you.
Use the integrated headset port (C) to effortlessly connect the Trigger to your controller, and mute/unmute the microphone with the flick of a switch (D).
Precision-Balanced, Amplified 40mm Speakers with Neodymium Magnets
Utilizing the highest quality drivers available for use in commercial headsets - - Neodymium - - high-fidelity game and chat audio is pumped through a pair of amplified 40mm speakers for deep bass and crystal-clear highs.
Includes Everything Needed to Connect to any Xbox 360
Whether your console is legacy or current-gen and connected to a display via HDMI or component/VGA/composite, the Trigger is ready to go right out of the box. All required cables and adapters are included to ensure you can connect to any Xbox 360 within minutes.
Flexible Performance Mic
Fixed microphones may not always properly align with your mouth, resulting in decreased sound quality when communicating over Xbox LIVE. Problem solved with the Trigger's flexible solution - - it provides the freedom to bend the mic into a position that's optimal for picking up your voice. The unique design allows the mic to fold up and out of the way when not in use.
Ergonomically Designed for Extreme Comfort
When blasting zombies for hours on end, headset comfort is a must. The Trigger delivers with a padded, adjustable headrail - - which extends an extra 1.25 inches on either side to accommodate a wide range of head sizes - - and soft, pliable earcups which swivel to provide a comfortable around-the-neck resting position.
Tritton Trigger Stereo Headset - headset
Headset - wired
Recommended Use
Game console
Headphones Form Factor
Full size
Wired
Sound Output Mode
Stereo
Microphone
Boom
Microphone Operation Mode
Mono
Controls
Mute, volume
Xbox 360
Headset
Recommended Use
Game console
Headphones
Circumaural
Wired
Available Microphone
Sound Output Mode
Stereo
Diaphragm
40 mm
Magnet Material
Neodymium
In-Cord Volume Control
Microphone
Boom
Mono
Remote Control
Controls
Mute, volume
Connector Type
Headset , USB ( 4 PIN USB Type A )
Headset cable - 4.27 m
Xbox 360
