BT.com
Wishlist
Tritton Kama Stereo Gaming Headset for PS4 and PS Vita - Black
Delivery
Standard Due date unavailable
Your Gateway to PS4 Online Chat
Specially built for the PlayStation 4 system's multiplayer online environments, TRITTON's Kama Stereo Headset delivers a comfortable audio experience while simplifying online chat. Directly connecting to the DUALSHOCK 4 wireless controller - and nearly any device with a 3.5mm jack - you're free to play in full stereo no matter where the game takes you.
Intuitive Plug-and-Play Connectivity
Prepping the Kama for voice chat is very straightforward. Simply plug the 3.5mm cable into the PS4 wireless controller and the connection process is complete.
Designed for PlayStation 4 Online Chat and Party Chat
Whether your game of choice is FIFA 14 or Call of Duty: Ghosts, the Kama will transform your online PS4 gaming experience by opening up the lines of communication with remote gamers. Courtesy of the PS4's Party function, you can use the Kama to chat with up to seven of your friends and fellow players.
Uncomplicated In-line Audio Controls
A handy in-line audio controller features an easy-to-use volume control for quick sound adjustments. And for those occasions when privacy matters, mute the microphone by simply sliding a switch.
Flexible Performance Mic
Fixed microphones may not always properly align with your mouth, resulting in decreased sound quality when communicating over PSN. Problem solved with the Kama's flexible solution - it provides the freedom to bend the mic into a position that's optimal for picking up your voice.
Designed for Extreme Comfort
Headset comfort is of utmost importance during extended gaming sessions. The Kama keeps your ears comfy with its padded, adjustable headrail, which extends an extra 1.25 inches on either side to accommodate a wide range of head sizes. When it's time for a break from the action, the soft earcups swivel to provide a comfortable around-the-neck resting position.
Take it With You
At home, work, or on-the-go, your music, videos and games can travel everywhere with you. Not limited to use with gaming consoles, the Kama is also compatible with most phones, tablets, and MP3 players.
Product Includes:
Stereo Headset with In-line Audio Controller and Flexible Microphone
Product Specifications:
  • Cable Length: 3.3ft/1m
  • Speaker Diameter: 40mm
  • Ear Coupling: Supra-aural (On-ear)
  • Magnet Type: Neodymium
  • Frequency Response: 20Hz-20kHz
  • Total Harmonic Distortion (THD): <1%
  • Resistance: 16 ohms
  • Audio Input Type: 3.5mm Connector
Tritton Kama - headset
Headset - wired
Recommended Use
Game console, portable electronics
Headphones Form Factor
On-ear
Wired
Sound Output Mode
Stereo
Audio Specifications
Frequency Response 20 - 20000 Hz
Impedance
16 Ohm
Microphone
Boom
Controls
Mute
Sony PlayStation 4
Headset
Recommended Use
Headphones
Supraaural
Wired
Available Microphone
Sound Output Mode
Stereo
Frequency Response
20 - 20000 Hz
1.0%
Impedance
16 Ohm
Diaphragm
40 mm
Magnet Material
Neodymium
In-Cord Volume Control
Microphone
Boom
Remote Control
Controls
Mute
Connector Type
Headset (mini-phone stereo 3.5 mm)
Headset cable - 1 m
Sony PlayStation 4
Customer reviews
Write review The opinions expressed in this reviews section are those of our customers and not of BT Shop. Nothing contained herein amends BT Shop’s terms and conditions.
4* Great Budget PS4 Headset
Reviewed by Anonymous on 28/04/2014
Great headset considering the price. Doesnt quite produce the sound of more expensive models such as the Kunai but what do you expect for 20 pound?! Sounds better than your TV, quite comfortable and my online friends say they can hear me very clearly.
If you do not want to spend a lot on a headset then you cannot go wrong with this!
Scroll to top
