BT.com
Wishlist
TRENDnet TV-IP450PI Outdoor 1.3 MP HD PoE IR Speed Dome Network Camer
TRENDnet TV-IP450PI Outdoor 1.3 MP...
£888.50
Hurry, only 1 left in stock!
£888.50
Add to wishlist
Delivery
Standard 1-3 working days
TRENDnet's Outdoor 1.3 MP HD PoE IR Speed Dome Network Camera, model TV-IP450PI, offers powerful 20x optical zoom, 100 m (330 feet) night vision, an IP66 weather rating, and endless 360 degree PTZ functionality. Record 1.3 Megapixel HD video (1280 x 960) at 30 fps in a space saving H.264 compression format.
Manage up to 32 TRENDnet cameras with included complimentary software and mobile apps.
A separate mounting bracket is required--install with TRENDnet's TV-HC400, TV-HW400, TV-HP400, or TV-HN400.
TRENDnet TV TV-IP450PI Outdoor 1.3 MP HD PoE IR Speed Dome Network Camera - network surveillance camera
Network surveillance camera - pan / tilt / zoom - outdoor - weatherproof
Audio
Yes: two-way audio capability
22 cm x 22 cm x 35.4 cm
4.4 kg
Wired
Camera
Colour - Day&Night
Optical Zoom
20 x
Max Resolution
1280 x 960
Frame Rate
30 frames per second
Optical Sensor Type
CMOS - 1/3" - 1.3 MP
Minimum Illumination
0.05 lux - colour , 0.01 lux - B&W , 0 lux - IR
Focal Length Control
Vari-focal
Focal Length
4.7 mm - 94 mm
Focus Adjustment
Automatic, manual
Lens Iris
F/1.4-3.5
Panning Range (degree)
360
Tilting Range (degree)
-5 to 90
Ethernet 10Base-T/100Base-TX
Voltage
PoE
Digital noise reduction, sharpness control, remote control, white balance, saturation control, brightness control, contrast control, image mirror, heater, manually schedule recording, auto patrol, Motion Detection Technology, microSD card slot, Privacy Mask Function, Digital Wide Dynamic Range (D-WDR), 256 preset positions, tamper-detection, notification picture to E-mail, ONVIF V2.2 (Profile S) support, snapshot function
3 years warranty
Environmental Parameters (operating)
-30 °C - 65 °C; 0 - 90% (non-condensing) relative humidity
Audio Support
Wired
22 cm
22 cm
35.4 cm
4.4 kg
Camera
Colour - Day&Night - pan / tilt / zoom - outdoor - weatherproof
Digital Video Format
MJPEG, H.264
Max Digital Video Resolution
1280 x 960
Digital Zoom
16
Exposure Range
1 sec - 1/10000 sec
Infrared Distance
100 m
Video Capture
1280 x 960 @ 30 fps , 704 x 480 @ 30 fps
Still Image Capture Resolution
1280 x 960, 704 x 480
Image Sensor
1.3 MP CMOS 1/3"
Lens Construction
Vari-focal
Optical Zoom
20 x
Focal Length
4.7 mm - 94 mm
Lens Iris
F/1.4-3.5
Focus Adjustment
Automatic, manual
Horizontal Field of View (degree)
54
Panning
Range (degree)
360
Speed (degree/sec)
Up to 240
Titling
Range (degree)
-5 to 90
Speed (degree/sec)
Up to 200
Network Interface
Network Protocols
DDNS, DHCP, DNS, FTP, HTTP, NTP, SMTP, TCP/IP, UDP/IP, ICMP, SNMP 1, SNMP 2c, SNMP 3, RTSP, RTP, HTTPS, UPnP, IPv4, IPv6, PPPoE, SMB, IGMP, CIFS
Supported Memory Cards
microSD Card
Power injector
FCC, IP66
Power Requirements
PoE
35 Watt
Software Included
Drivers & Utilities, TRENDnetVIEW Pro
Microsoft Windows Server 2003, Microsoft Windows Vista / XP, Microsoft Windows Server 2008, Android, Apple iOS, Microsoft Windows 7 / Windows 8, Windows 8.1
Limited warranty - 3 years
-30 °C
65 °C
Relative Humidity (operating)
Scroll to top
