BT.com
Wishlist
TRENDnet TV-IP320PI Outdoor 1.3 MP HD PoE IR Network Camera
TRENDnet TV-IP320PI Outdoor 1.3 MP...
£73.59
12 in stock
£73.59
Add to wishlist
Delivery
Standard 3-5 working days
The Outdoor 1.3 MP HD PoE IR Network Camera, model TV-IP320PI, provides powerful 1.3 megapixel HD night vision in complete darkness for up to 30 meters (100 ft.).
This ultra-compact camera is outdoor ready with an IP66 weather rated housing.
It comes with a free Apple and Android mobile app and Complimentary pro-grade software to manage up to 32 TRENDnet cameras.
TRENDnet TV IP320PI - network surveillance camera
Network surveillance camera - fixed - outdoor - weatherproof
6 cm x 15.2 cm x 6 cm
375 g
Wired
Camera
Colour - Day&Night
Max Resolution
1280 x 960
Frame Rate
30 frames per second
Optical Sensor Type
CMOS - 1/3" - 1.3 MP
Minimum Illumination
0.01 lux - colour - F2.0 , 0 lux - IR
Focal Length
4 mm
Focus Adjustment
(min distance 20 cm)
Ethernet 10Base-T/100Base-TX
Voltage
DC 12 V / PoE
Digital noise reduction, date/time stamp, sharpness control, white balance, progressive scanning, saturation control, brightness control, sunshield, contrast control, e-mail alerts, image mirror, ONVIF support, 3D Noise Reduction Technology, manually schedule recording, Motion Detection Technology, built-in IR illuminator, Privacy Mask Function, Digital Wide Dynamic Range (D-WDR), text stamp, tamper-detection, Smart IR, ONVIF V2.2 (Profile S) support, reset button, snapshot function
3 years warranty
Environmental Parameters (operating)
-30 °C - 60 °C; 0 - 95% (non-condensing) relative humidity
Wired
6 cm
15.2 cm
6 cm
375 g
Camera
Colour - Day&Night - fixed - outdoor - weatherproof
Digital Video Format
H.264
Max Digital Video Resolution
1280 x 960
Exposure Range
1/3 sec - 1/10000 sec
Infrared Distance
30 m
Video Capture
704 x 480 @ 30 fps , 1280 x 960 @ 30 fps
Still Image Capture Resolution
1280 x 960, 704 x 480
Image Sensor
1.3 MP CMOS 1/3"
Lens Construction
Focal Length
4 mm
Min Focus Distance
20 cm
Horizontal Field of View (degree)
70
Vertical Field of View (degree)
52
Network Interface
Network Protocols
DDNS, DHCP, DNS, FTP, HTTP, NTP, SMTP, TCP/IP, UDP/IP, ICMP, SNMP 1, SNMP 2c, SNMP 3, RTSP, RTP, HTTPS, UPnP, IPv4, IPv6, Bonjour, RTCP, PPPoE, SMB, SSL, CIFS
Ports
LAN/power - RJ-45
UL 60950, FCC, IP66
Power Requirements
DC 12 V / PoE - 1 A
Power adapter 7 Watt
Software Included
TRENDnetVIEW Pro
Microsoft Windows Server 2003, Microsoft Windows Vista / XP, Microsoft Windows Server 2008, Microsoft Windows 7 / 8 / 8.1
Limited warranty - 3 years
-30 °C
60 °C
Relative Humidity (operating)
Scroll to top
