BT.com
Wishlist
TRENDnet TPL-410APK Powerline 500 Wireless Kit
TRENDnet TPL-410APK Powerline 500...
£68.77
34 in stock
£68.77
Add to wishlist
Delivery
Standard 3-5 working days
TRENDnet's Powerline TPL-410APK, uses electrical outlets to create a hybrid Powerline-wireless network. The included TREND-net Powerline adapters auto-connect out of the box. Network the TPL-406E to a router and plug the TPL-410AP into an outlet on the electrical system to extend a high performance wireless network. Hard-wire a smart TV, gaming console, or media player to the two Ethernet ports on the TPL-410AP.
TRENDnet TPL-410APK - bridge - 802.11b/g/n - wall-pluggable
Bridge
Enclosure Type
Wall-pluggable
Ethernet, Fast Ethernet, IEEE 802.11b, IEEE 802.11g, IEEE 802.11n, HomePlug AV (HPAV)
Frequency Band
2.4 GHz
Data Transfer Rate
500 Mbps
Access Point operational mode, Wi-Fi Protected Setup (WPS), reset button, sync button
IEEE 802.3, IEEE 802.3u, IEEE 802.11b, IEEE 802.3x, IEEE 802.11g, IEEE 802.11n, HomePlug AV, IEEE 802.3az, IEEE 1901
Microsoft Windows Vista / XP / 7 / 8, Windows 8.1
3 years warranty
Bridge
Enclosure Type
Wall-pluggable
Wireless, wired
Frequency Band
2.4 GHz
Data Transfer Rate
500 Mbps
Encryption Algorithm
WPA2, 128-bit AES
IEEE 802.3, IEEE 802.3u, IEEE 802.11b, IEEE 802.3x, IEEE 802.11g, IEEE 802.11n, HomePlug AV, IEEE 802.3az, IEEE 1901, FCC
2 x 10Base-T/100Base-TX - RJ-45
Aerial
Aerial
Internal
Antenna Qty
2
Gain Level
3 dBi
Internal power supply
8 Watt
TRENDnet Powerline 500 AV Nano Adapter TPL-406E
2 x network cable - 1.8 m
Software Included
Drivers & Utilities
Limited warranty - 3 years
0 - 90% (non-condensing)
Scroll to top
