BT.com
Wishlist
TRENDnet TPL-410AP Powerline 500 AV Wireless Access Point
Delivery
Standard 3-5 working days
TRENDnet's Powerline 500 AV Wireless Access Point, model TPL-410AP, uses an electrical outlet to create or expand a wireless network. Two Powerline adapters are needed to start a network. Connect one adapter to a router and plug in the TPL-410AP on your electrical system to create or expand a high performance wireless network.
TRENDnet TPL-410AP - bridge - 802.11b/g/n - wall-pluggable
Bridge
Enclosure Type
Wall-pluggable
Ethernet, Fast Ethernet, IEEE 802.11b, IEEE 802.11g, IEEE 802.11n, HomePlug AV (HPAV)
Frequency Band
2.4 GHz
Data Transfer Rate
500 Mbps
Access Point operational mode, Wi-Fi Protected Setup (WPS), reset button, sync button
IEEE 802.3, IEEE 802.3u, IEEE 802.11b, IEEE 802.3x, IEEE 802.11g, IEEE 802.11n, HomePlug AV, IEEE 802.3az, IEEE 1901
6.5 cm x 7 cm x 10 cm
168 g
Microsoft Windows Vista / XP / 7 / 8, Windows 8.1
United Kingdom
3 years warranty
Bridge
Enclosure Type
Wall-pluggable
Wireless, wired
Frequency Band
2.4 GHz
Data Transfer Rate
500 Mbps
Encryption Algorithm
WPA2, 128-bit AES
IEEE 802.3, IEEE 802.3u, IEEE 802.11b, IEEE 802.3x, IEEE 802.11g, IEEE 802.11n, HomePlug AV, IEEE 802.3az, IEEE 1901, FCC
2 x 10Base-T/100Base-TX - RJ-45
Aerial
Aerial
Internal
Gain Level
3 dBi
Internal power supply
8 Watt
1 x network cable - 1.8 m
United Kingdom
Software Included
Drivers & Utilities
6.5 cm
7 cm
10 cm
168 g
Limited warranty - 3 years
0 - 90% (non-condensing)
Scroll to top
