BT.com
Wishlist
TRENDnet TPL-408E2K Powerline 500 AV2 Adapter Kit
TRENDnet TPL-408E2K Powerline 500...
£69.85
500mbps Powerline with gigabit port - Was £46.98!
7 in stock
£69.85
Add to wishlist
Delivery
Standard 3-5 working days
TRENDnet's Powerline 500 AV2 adapter kit, model TPL-408E2K, comes with two Powerline adapters to create a high performance Powerline network using an existing electrical system.
No CD installation required - encrypted TRENDnet adapters auto-connect out of the box. Connect one adapter to a router and plug in another adapter on your electrical system for instant Internet access.
Ease of Use -
No CD Installation - Simply plug in the adapters--all TRENDnet adapters auto-connect out of the box
Cross Compatible
TRENDnet Powerline 600, 500 and 200 adapters work with each other
Compact
Compact form factor saves space around a crowded electrical outlet
Security
Pre-Encrypted - For your security the adapter arrives pre-encrypted
Sync Button
Press the Sync button to change existing encryption keys
Performance
Powerline 500 - 500 Mbps Powerline networking over existing electrical lines
Whole Home Coverage
Connects over electrical lines for distances of up to a 5,000 sq. ft. home or 300 m (980 ft.) linear distance over electrical power lines
Energy Savings
Power Save mode reduces electrical consumption by up to 80%
*Maximum of 8 adapters (nodes) recommended for streaming video across your network.
*500 Mbps is the maximum physical Powerline data rate. Data throughput may vary by circuit wire condition overheads.
*Powerline communication works only single area electric circuit. (Usually controlled by a single power breaker.)
*Power strip, GFCI outlets and AFCI circuit breakers will degrade Powerline network signals.
TRENDnet TPL-408E2K - bridge - wall-pluggable
Bridge
Enclosure Type
Wall-pluggable
Ethernet, Fast Ethernet, Gigabit Ethernet, HomePlug 1.0, HomePlug AV (HPAV) 2.0
Data Transfer Rate
500 Mbps
Reset button, sync button
IEEE 802.3, IEEE 802.3u, IEEE 802.3ab, IEEE 802.3x, HomePlug 1.0, HomePlug AV 2.0, IEEE 1901
5.5 cm x 5.8 cm x 8.7 cm
90 g
Microsoft Windows Vista / XP / 7 / 8, Windows 8.1
United Kingdom
3 years warranty
Bridge
Enclosure Type
Wall-pluggable
Wired
Data Transfer Rate
500 Mbps
Encryption Algorithm
128-bit AES
IEEE 802.3, IEEE 802.3u, IEEE 802.3ab, IEEE 802.3x, HomePlug 1.0, HomePlug AV 2.0, IEEE 1901, FCC
Status Indicators
Status
1 x 10Base-T/100Base-TX/1000Base-T - RJ-45
Internal power supply
3.9 Watt
TRENDnet Powerline 500 AV2 Adapter TPL-408E2K
2 x network cable - 1.5 m
United Kingdom
Software Included
Drivers & Utilities
5.5 cm
5.8 cm
8.7 cm
90 g
Limited warranty - 3 years
0 - 90% (non-condensing)
Customer reviews
Write review The opinions expressed in this reviews section are those of our customers and not of BT Shop. Nothing contained herein amends BT Shop’s terms and conditions.
5* Plug and Play
Reviewed by Peter Danckwerts on 07/07/2014
This kit comes with a visual quick start guide and a CD but you don't need either.
Networking doesn't get any easier than this. Just plug one of these in a socket near your router and connect it to the router with an ethernet cable (2 fairly short ones supplied) and plug another near your computer and attach that with another ethernet cable. Job done.
I have a fast but rather unreliable wifi connection. This kit gives me the reliability I need. Usually pass-through plugs are quite expensive but these a very reasonably priced. They look good, they're reasonably small and they seem to be well-built.
I really can't fault them.
4* Not bad. Worth considering
Reviewed by Anonymous on 12/12/2014
Bought this kit to replace a wi-fi bridge that linked my, upstairs, fibre broadband (38Mb/s) to my, downstairs, tv and surround cinema system together with a 5 port gigabyte switch. The wi-fi link was a bit slow and struggled to keep up with netflix/iPlayer etc which was usually buffering.
The kit setup was not as straight forward as explained in the documentation. The transceivers were, apparently already synced, so did not follow the 'sync' set up procedure. The accompanying CDROM did not not have the detailed User Manual which is definitely required, accessible from the on screen menu. It is on the disc but one has to search for it manually.
The S/W Utility is a bit flakey in that it does not always report the data bit rate. Go with the LED indicators on the transceivers.
The kit is rated at 500Mb/s. This is misleading, the best one will get is circa 261Mb/s. I ended up with a data bit rate of 115Mb/s across two ring mains and a RCD consumer unit. No more buffering!!
Scroll to top
