BT.com
Wishlist
TRENDnet TPL-408E Powerline 500 AV2 Adapter
TRENDnet TPL-408E Powerline 500 AV2...
£33.98
5 in stock
£33.98
Add to wishlist
Delivery
Standard 3-5 working days
TRENDnet's Powerline 500 AV2 Adapter, model TPL-408E, uses an electrical outlet to create a 500 Mbps Powerline network. No CD installation required - encrypted TRENDnet adapters auto-connect out of the box. Two adapters are needs to start a network. Connect one adapter to a router and plug in another adapter on your electrical system for instant Internet access.
TRENDnet TPL-408E - bridge - wall-pluggable
Bridge
Enclosure Type
Wall-pluggable
Ethernet, Fast Ethernet, Gigabit Ethernet, HomePlug 1.0, HomePlug AV (HPAV) 2.0
Data Transfer Rate
500 Mbps
Reset button, sync button
IEEE 802.3, IEEE 802.3u, IEEE 802.3ab, IEEE 802.3x, HomePlug 1.0, HomePlug AV 2.0, IEEE 1901
5.5 cm x 5.8 cm x 8.7 cm
90 g
Microsoft Windows Vista / XP / 7 / 8
United Kingdom
3 years warranty
Bridge
Enclosure Type
Wall-pluggable
Wired
Data Transfer Rate
500 Mbps
Encryption Algorithm
128-bit AES
IEEE 802.3, IEEE 802.3u, IEEE 802.3ab, IEEE 802.3x, HomePlug 1.0, HomePlug AV 2.0, IEEE 1901, FCC
Status Indicators
Status
1 x 10Base-T/100Base-TX/1000Base-T - RJ-45
Internal power supply
3.9 Watt
1 x network cable - 1.5 m
United Kingdom
Software Included
Drivers & Utilities
5.5 cm
5.8 cm
8.7 cm
90 g
Limited warranty - 3 years
0 - 90% (non-condensing)
Scroll to top
