BT.com
Wishlist
TRENDnet TPL-407E Powerline 500 AV Nano Adapter with Built-In Outlet
Delivery
Standard 3-5 working days
The Powerline 500 AV nano adapter with built-in outlet, model TPL-407E, uses existing electrical lines to create a secure high speed network. Two adapters are needed to start a network. Connect one adapter to your router and plug another adapter into an outlet on your electrical system for instant high speed network access. The compact form factor saves space and offers an additional electrical outlet, built into the front of the housing to power computers and other devices. A noise filter maintains optimum connection speeds when devices such as computers, televisions, and gaming consoles create electrical background noise.
This adapter automatically connects to other TRENDnet Powerline AV adapters with no installation required - TRENDnet recommends pressing the 'sync' button to automatically change default encryption keys. Use up to 8 adapters to network devices in different rooms without running new cabling. Power Save mode reduces power consumption by up to 80%. Quality of Service technology prioritizes video, audio, and online gaming. LED displays convey device status for easy troubleshooting. Advanced 128-bit AES encryption secures your network. This adapter is ideal for use in buildings that interfere with wireless networking signals.
TRENDnet TPL-407E - bridge - wall-pluggable
Bridge
Enclosure Type
Wall-pluggable
Ethernet, Fast Ethernet, HomePlug AV (HPAV)
Data Transfer Rate
500 Mbps
Maximum of neighbouring networks: 4 , Nodes: 8
Network / Transport Protocol
CSMA/CA
Auto-uplink (auto MDI/MDI-X), IPv6 support, full duplex mode, Quality of Service (QoS), reset button
IEEE 802.3, IEEE 802.3u, IEEE 802.3x, HomePlug AV, IEEE 1901
5.5 cm x 7.8 cm x 7.7 cm
138 g
Microsoft Windows Vista (32/64 bits), Microsoft Windows 7 (32/64 bits), Microsoft Windows XP (32/64 bits)
Europe
3 years warranty
Bridge
Enclosure Type
Wall-pluggable
Wired
Data Transfer Rate
500 Mbps
CSMA/CA
Encryption Algorithm
128-bit AES
IEEE 802.3, IEEE 802.3u, IEEE 802.3x, HomePlug AV, IEEE 1901, FCC, RoHS, WEEE
Status Indicators
Link activity, power
Line Properties
Line Coding Format
8 QAM, 64 QAM, 256 QAM, BPSK, QPSK, OFDM, ROBO, 1024 QAM
1 x 10Base-T/100Base-TX - RJ-45
Internal power supply
3 Watt
1 x network cable - 1.5 m
Europe
Software Included
Drivers & Utilities
5.5 cm
7.8 cm
7.7 cm
138 g
Limited warranty - 3 years
0 - 95% (non-condensing)
Scroll to top
