BT.com
Wishlist
TRENDnet TL2-E284 24-Port 10/100Mbps Layer 2  Switch
TRENDnet TL2-E284 24-Port...
£145.08
£145.08
Add to wishlist
Delivery
Standard 1-3 working days
The 24-port 10/100 Mbps Layer 2 switch with 4 Gigabit ports and 2 shared Mini-GBIC slots, model TL2-E284, provides a reliable foundation for a highly scalable managed network. The TL2-E284 features a 12.8 Gbps switch fabric, 802.1x authentication, SNMP v3, and Multiple Spanning Tree (MSTP) support.
Built-in Gigabit Ethernet ports and Mini-GBIC slots provide high speed uplinks to backbone switching or servers. Additional management features such as port trunking, IGMP snooping, static and dynamic VLAN, load balancing, RMON, QoS, and RSTP allow administrators to effectively manage departmental work groups.
TRENDnet TL2 E284 - switch - 24 ports - Managed - rack-mountable
Switch - 24 ports - Managed
Enclosure Type
Rack-mountable 1U
Subtype
Fast Ethernet
Ports
24 x 10/100 + 2 x 10/100/1000 + 2 x combo Gigabit SFP
MAC Address Table Size
8K entries
Remote Management Protocol
SNMP 1, SNMP 2, RMON, Telnet, SNMP 3, HTTP, HTTPS, TFTP, SSH
Flow control, auto-negotiation, trunking, load balancing, VLAN support, auto-uplink (auto MDI/MDI-X), IGMP snooping, port mirroring, store and forward, Broadcast Storm Control, half duplex mode, full duplex mode, Multicast Storm Control, Spanning Tree Protocol (STP) support, Rapid Spanning Tree Protocol (RSTP) support, Multiple Spanning Tree Protocol (MSTP) support, Trivial File Transfer Protocol (TFTP) support, Access Control List (ACL) support, Quality of Service (QoS), RADIUS support, SSH support
IEEE 802.3, IEEE 802.3u, IEEE 802.3z, IEEE 802.1D, IEEE 802.1Q, IEEE 802.3ab, IEEE 802.1p, IEEE 802.3x, IEEE 802.3ad (LACP), IEEE 802.1w, IEEE 802.1x, IEEE 802.1s
44 cm x 14 cm x 4.4 cm
2 kg
3 years warranty
Bundled Services
3 years warranty
Enclosure Type
Rack-mountable 1U
Subtype
Fast Ethernet
Ports
8K entries
Authentication Method
RADIUS
Built-in Devices
Led panel
Status Indicators
Port status, link activity, power
24 x 10Base-T/100Base-TX - RJ-45 , 2 x SFP (mini-GBIC) , 4 x 10Base-T/100Base-TX/1000Base-T - RJ-45 , 1 x serial (RS-232)
Internal power supply
16.8 Watt
1 x serial cable - 3 m
Rack Mounting Kit
Included
FCC, RoHS
44 cm
14 cm
4.4 cm
2 kg
Limited warranty - 3 years
0 - 90% (non-condensing)
Min Storage Temperature
-10 °C
Max Storage Temperature
70 °C
Scroll to top
