BT.com
Wishlist
TRENDnet THA-101 Home Smart Switch (with Wireless Extender)
Delivery
Standard Due date unavailable
TRENDnet's Home Smart Switch with Wireless Extender, model THA-101, is a combination smart electrical outlet and powerful N300 wireless extender.
Create a daily schedule to turn on/off the outlet to match your needs or to give the illusion that you're home. Place the THA-101 in an area of your home with low wireless coverage - the powerful built-in N300 wireless extender connects to your existing wireless router and broadcasts a strong wireless network.
TRENDnet THA-101 Home Smart Switch - Wi-Fi range extender
External
IEEE 802.11b, IEEE 802.11g, IEEE 802.11n
Frequency Band
2.4 GHz
AC 120/230 V ( 50/60 Hz )
5.8 cm x 3.7 cm x 9.3 cm
156 g
3 years warranty
5.8 cm
3.7 cm
9.3 cm
156 g
External
Wireless
Data Transfer Rate
300 Mbps
Line Coding Format
DBPSK, DQPSK, CCK, 64 QAM, BPSK, QPSK, 16 QAM, OFDM
Network / Transport Protocol
CSMA/CA
Frequency Band
2.4 GHz
Selectable Channels Qty
13
Remote Power On, remote Power Off, MIMO technology, Wi-Fi Protected Setup (WPS), integrated power socket, reset button, over-current protection, on/off switches
Encryption Algorithm
WPA, WPA2, WPA-PSK, WPA2-PSK, WEP
Authentication Method
RADIUS
Aerial
Antenna
Internal
Antenna Qty
2
Gain Level
2 dBi
FCC
Internal power supply
6 Watt
Limited warranty - 3 years
0 - 95% (non-condensing)
Scroll to top
