BT.com
Wishlist
TRENDnet TEW-818DRU AC1900 Dual Band Wireless Router
TRENDnet TEW-818DRU AC1900 Dual...
£123.64
£123.64
Add to wishlist
Delivery
Standard Due date unavailable
TRENDnet's AC1900 dual-band wireless router, model TEW-818DRU, is an extreme performance wireless router. It creates two concurrent wireless networks - a 1.3 Gigabit wireless AC network and a 600 Mbps Wireless N network to connect common wireless devices. Use the high speed USB 3.0 port and Gigabit Ethernet ports to further expand your network.
TRENDnet TEW-818DRU - wireless router - 802.11a/b/g/n/ac (draft 2.0) - desktop
Wireless router - 4-port switch (integrated)
Enclosure Type
Desktop
Ethernet, Fast Ethernet, Gigabit Ethernet, IEEE 802.11b, IEEE 802.11a, IEEE 802.11g, IEEE 802.11n, IEEE 802.11ac
Frequency Band
2.4 GHz / 5 GHz
Data Transfer Rate
1.3 Gbps
Network / Transport Protocol
DDNS
NAT support, Stateful Packet Inspection (SPI), MAC address filtering, IPv6 support, Wireless Distribution System (WDS) support, URL filtering, parental control, IP address filtering, GREENnet technology, Quality of Service (QoS), Wi-Fi Protected Setup (WPS), Samba support, FTP server, pre-encrypted
IEEE 802.3, IEEE 802.3u, IEEE 802.3ab, IEEE 802.11b, IEEE 802.11a, IEEE 802.11g, IEEE 802.11n, IEEE 802.11ac (draft 2.0)
AC 120/230 V (50 - 60 Hz)
15.5 cm x 4.8 cm x 18 cm
395 g
Microsoft Windows XP, Apple MacOS X 10.4, Microsoft Windows Vista, Apple MacOS X 10.6, Apple MacOS X 10.5, Apple MacOS X 10.7 Lion, Apple MacOS X 10.8, Microsoft Windows 7 / Windows 8, Windows 8.1, Apple MacOS X 10.9
3 years warranty
Enclosure Type
Desktop
Wireless, wired
Frequency Band
2.4 GHz / 5 GHz
Data Transfer Rate
1.3 Gbps
DDNS
Encryption Algorithm
WPA2
Authentication Method
Radio Service Set ID (SSID)
IEEE 802.3, IEEE 802.3u, IEEE 802.3ab, IEEE 802.11b, IEEE 802.11a, IEEE 802.11g, IEEE 802.11n, IEEE 802.11ac (draft 2.0), ETSI, FCC
WAN: 1 x 10Base-T/100Base-TX/1000Base-T - RJ-45 , LAN: 4 x 10Base-T/100Base-TX/1000Base-T - RJ-45 , USB 2.0: 1 x 4 pin USB Type A , USB 3.0: 1 x 9 pin USB Type A
Aerial
Aerial
Internal
Antenna Qty
2
Gain Level
6 dBi
External power adapter
22 Watt
1 x network cable - 1.5 m
Software Included
Drivers & Utilities
15.5 cm
4.8 cm
18 cm
395 g
Limited warranty - 3 years
0 - 90% (non-condensing)
Scroll to top
