BT.com
Wishlist
TRENDnet TEW-812DRU AC1750 Dual Band Wireless Router
TRENDnet TEW-812DRU AC1750 Dual...
£123.64
£123.64
Add to wishlist
Delivery
Standard Due date unavailable
TRENDnet's AC1750 Dual Band Wireless Router, model TEW-812DRU, produces the ultimate wireless experience with gigabit wireless speeds. Manage two wireless networks--the 1300 Mbps Wireless AC band for the fastest wireless available and the 450 Mbps Wireless N band to connect common wireless devices. The TEW-812DRU can easily handle the demands of multiple HD streams in a busy connected home.
Plug in a USB flash or NAS drive to share HD videos and music across the network. Gigabit ports on the back of the router maintain high speed wired connections. Create a secure isolated guest network for guest internet access. Wi-Fi Protected Setup (WPS) connects other WPS supported wireless adapters at the touch of a button. Manage access to websites and file types with advanced access controls.
Gigabit Wireless: Next generation Gigabit Wireless AC
Simultaneous Dual Band: Gigabit Wireless AC band + Wireless N band for every day devices
One Touch Connection: Connect to the router at the touch of the Wi-Fi Protected Setup (WPS) button
Guest Network Access: Create an isolated network for guest internet access
USB Share Port: Plug in a USB flash or NAS drive to share HD videos and music
Parental Controls: Control access to specific websites or types of content
Gigabit Wired: Gigabit Ethernet port maintains high performance network connections
TRENDnet TEW-812DRU - wireless router - 802.11a/b/g/n/ac (draft 2.0) - desktop
Wireless router - 4-port switch (integrated)
Enclosure Type
Desktop
Ethernet, Fast Ethernet, Gigabit Ethernet, IEEE 802.11b, IEEE 802.11g, IEEE 802.11n
Frequency Band
2.4 GHz / 5 GHz
Data Transfer Rate
1.3 Gbps
Network / Transport Protocol
PPTP, L2TP, NTP, IPSec, PPPoE, DDNS
Routing Protocol
IGMPv2, IGMP, IGMPv3
Firewall protection, DMZ port, NAT support, auto-uplink (auto MDI/MDI-X), IGMP snooping, Stateful Packet Inspection (SPI), ALG support, dynamic DNS server, MAC address filtering, IPv6 support, VPN passthrough, Wireless Distribution System (WDS) support, URL filtering, IP address filtering, firmware upgradable, Wi-Fi Multimedia (WMM) support, Quality of Service (QoS), virtual server support, Wi-Fi Protected Setup (WPS), DHCP server, static IP mode, reset button, IPv4 support, dynamic IP mode, USB device server
IEEE 802.3, IEEE 802.3u, IEEE 802.3ab, IEEE 802.11b, IEEE 802.11a, IEEE 802.11g, IEEE 802.11n, UPnP, IEEE 802.11ac (draft 2.0)
AC 120/230 V (50 - 60 Hz)
15.5 cm x 4.8 cm x 18 cm
395 g
Apple MacOS X 10.4 - 10.7, Microsoft Windows Vista / XP / 7 / 8
3 years warranty
Enclosure Type
Desktop
Wireless, wired
Frequency Band
2.4 GHz / 5 GHz
Data Transfer Rate
1.3 Gbps
Selectable Channels Qty
13
Routing Protocol
Encryption Algorithm
128-bit WEP, 64-bit WEP, WPA-PSK, WPA2-PSK
Authentication Method
RADIUS
IEEE 802.3, IEEE 802.3u, IEEE 802.3ab, IEEE 802.11b, IEEE 802.11a, IEEE 802.11g, IEEE 802.11n, UPnP, IEEE 802.11ac (draft 2.0), ETSI, FCC, RoHS, WEEE
Status Indicators
Power, WLAN, WAN, LAN, WPS
Line Properties
Line Coding Format
DBPSK, DQPSK, CCK, 64 QAM, 256 QAM, BPSK, QPSK, 16 QAM, OFDM
WAN: 1 x 10Base-T/100Base-TX/1000Base-T - RJ-45 , LAN: 4 x 10Base-T/100Base-TX/1000Base-T - RJ-45 , USB 2.0: 1 x 4 pin USB Type A
Aerial
Aerial
Internal
Antenna Qty
3
Gain Level
2 dBi
External power adapter
18 Watt
1 x network cable - 1.5 m
Software Included
Drivers & Utilities
15.5 cm
4.8 cm
18 cm
395 g
Limited warranty - 3 years
0 - 90% (non-condensing)
Customer reviews
Write review The opinions expressed in this reviews section are those of our customers and not of BT Shop. Nothing contained herein amends BT Shop’s terms and conditions.
3* Not sure about this
Reviewed by Anonymous on 29/03/2014
Maybe I'm not typical but, despite this looking good and appearing very good value, I am not convinced about this product. It does work (and at times very well) but seems to be quite dodgy - especially with Windows 8.1. Compared with similar products from different companies, it is quite cheap and has lots of the bells and whistles. Or it might be that it just doesn't work in partnership with the Trendnet ac USB 3 dongle which I also bought.
2* BT HomeHub 2 replacement
Reviewed by C S on 18/07/2014
Tried to replace a BT HomeHub 2 with this and now get worse coverage than before. The unit I received is a discontinued model/version. While I did get tech support from Trendnet the set up was not the easiest and performance (compared to BTHH2) leaves to be desired.
Scroll to top
