BT.com
Wishlist
TRENDnet TEW-805UB AC1200 Dual Band Wireless USB Adapter
TRENDnet TEW-805UB AC1200 Dual Band...
£31.05
23 in stock
£31.05
Add to wishlist
Delivery
Standard 3-5 working days
TRENDnet's AC1200 Dual Band Wireless USB Adapter, model TEW-805UB, connects a laptop or desktop computer to a revolutionary Wireless AC network. Connect to a Wireless AC network at an amazing 867 Mbps or to a Wireless N network at up to 300 Mbps. A SuperSpeed 5 Gbps USB 3.0 port maintains a high speed connection to your computer.
Quickly connect to a Wireless AC or N network at the touch of a button with the convenience of one-touch Wi-Fi Protected Setup (WPS). An LED on the front of the adapter conveys device status. Upgrade your computer's wireless connection to experience the speed of revolutionary Wireless AC.
Wireless AC: Next generation Wireless AC
Dual Band: Up to 867 Mbps Wireless AC or 300 Mbps Wireless N
Compatible: Connects to standard Wireless N networks
USB 3.0: SuperSpeed 5 Gbps USB 3.0 connection to computer
Coverage: Expanded coverage with MIMO technology
One Touch Connection: Connect to a router at the touch of the Wi-Fi Protected Setup (WPS) button
TRENDnet TEW-805UB - network adapter
Network adapter
External
Interface (Bus) Type
SuperSpeed USB 3.0
8 cm x 2.7 cm x 1.2 cm
20 g
802.11b, 802.11a, 802.11g, 802.11n, 802.11ac (draft 2.0)
Data Transfer Rate
867 Mbps
Network / Transport Protocol
CSMA/CA
Frequency Band
2.4 GHz, 5 GHz
IEEE 802.11b, IEEE 802.11a, IEEE 802.11g, USB 1.1, USB 2.0, IEEE 802.11n, USB 3.0, IEEE 802.11ac (draft 2.0)
Microsoft Windows Vista (32/64 bits), Microsoft Windows 7 (32/64 bits), Microsoft Windows XP (32/64 bits), Windows 8 (32/64 bits)
3 years warranty
Network adapter
External
SuperSpeed USB 3.0
Wireless
Data Transfer Rate
867 Mbps
CSMA/CA
Line Coding Format
128 QAM, DBPSK, DQPSK, CCK, 64 QAM, 256 QAM, BPSK, QPSK, 16 QAM, OFDM
Frequency Band
2.4 GHz, 5 GHz
Max Range Indoors
100 m
Max Range Open Space
300 m
Status Indicators
Status
MIMO technology, Wi-Fi Protected Setup (WPS)
Aerial
Antenna
Internal
Antenna Qty
2
1 x USB - 4 pin USB Type A
Encryption Algorithm
AES, 128-bit WEP, 64-bit WEP, TKIP, WPA, WPA2, WPA2-PSK
ETSI, FCC
Software Included
Drivers & Utilities
8 cm
2.7 cm
1.2 cm
20 g
3 years warranty
Service & Support Details
Limited warranty - 3 years
0 - 95% (non-condensing)
Customer reviews
Write review The opinions expressed in this reviews section are those of our customers and not of BT Shop. Nothing contained herein amends BT Shop’s terms and conditions.
5* impressed, great value
Reviewed by MT on 07/06/2014
although i only have n std wireless, at this price i decided to go for the ac1200, as i am sure ac will arrive where i live soon. easy to set up, just follow disc supplied, software not intrusive like some are, but if you want you can delete and just leave the driver. home built pc, good spec, running win 7 64 bit, the usb 3 connection sure makes a difference to connection, although still showing 300 mbs, the speed with which pages load is so much quicker, on both 5 & 2.4 bands. have had for 3 weeks & no problems yet, happy with purchase.
Scroll to top
