BT.com
Wishlist
TRENDnet TEW-752DRU N600 Dual Band Wireless Router
Delivery
Standard Due date unavailable
TRENDnet's N600 Dual Band Wireless Router, model TEW-752DRU, offers proven concurrent Dual Band 300 Mbps wireless n networking, Gigabit wired Ethernet ports, and a convenient USB share port. Embedded GREENnet technology reduces power consumption by up to 50%. For your security this router comes pre-encrypted and features guest networks.
TRENDnet TEW-752DRU - wireless router - 802.11a/b/g/n - desktop
Wireless router - 4-port switch (integrated)
Enclosure Type
Desktop
Ethernet, Fast Ethernet, Gigabit Ethernet, IEEE 802.11b, IEEE 802.11a, IEEE 802.11g, IEEE 802.11n
Frequency Band
2.4 GHz / 5 GHz
Data Transfer Rate
300 Mbps
Routing Protocol
Static IP routing
Firewall protection, NAT support, VPN support, Stateful Packet Inspection (SPI), dynamic DNS server, MAC address filtering, IPv6 support, VPN passthrough, URL filtering, parental control, IP address filtering, GREENnet technology, MIMO technology, Quality of Service (QoS), virtual server support, Wireless Guest Services, DHCP server, port forwarding, reset button, pre-encrypted, Internet Bandwidth Control
IEEE 802.3, IEEE 802.3u, IEEE 802.3ab, IEEE 802.11b, IEEE 802.11a, IEEE 802.11g, IEEE 802.11n, UPnP
AC 120/230 V (50 - 60 Hz)
4.5 cm x 11.8 cm x 16.4 cm
255 g
3 years warranty
Enclosure Type
Desktop
Wireless, wired
Frequency Band
2.4 GHz / 5 GHz
Data Transfer Rate
300 Mbps
Routing Protocol
Static IP routing
Encryption Algorithm
128-bit WEP, 64-bit WEP, WPA-PSK, WPA2-PSK
Authentication Method
RADIUS
IEEE 802.3, IEEE 802.3u, IEEE 802.3ab, IEEE 802.11b, IEEE 802.11a, IEEE 802.11g, IEEE 802.11n, UPnP, FCC, RoHS, WEEE
Status Indicators
Power, WAN, wireless, USB, WPS
Line Properties
Line Coding Format
DBPSK, DQPSK, CCK, 64 QAM, BPSK, QPSK, 16 QAM, OFDM
WAN: 1 x 1000Base-T - RJ-45 , LAN: 1 x 1000Base-T - RJ-45 , USB 2.0: 1 x 4 pin USB Type A
Aerial
Aerial
Internal
Antenna Qty
4
External power adapter
14.7 Watt
1 x network cable - 1.5 m
4.5 cm
11.8 cm
16.4 cm
255 g
Limited warranty - 3 years
0 - 95% (non-condensing)
Scroll to top
