BT.com
Wishlist
TRENDnet TEW-738APBO 10 dBi Outdoor PoE Access Point
TRENDnet TEW-738APBO 10 dBi Outdoor...
£179.80
Hurry, only 3 left in stock!
£179.80
Add to wishlist
Delivery
Standard 1-3 working days
TRENDnet's 10 dBi Outdoor PoE Access Point, model TEW-738APBO, provides Wireless N300 building-to-building connectivity forclear line of sight distances of up to 8 km (5 miles). A variety of installation scenarios are facilitated with Access Point (AP), WirelessDistribution System (WDS), Repeater, and CPE + AP modes.
The rugged aluminum IP67 rated housing comes with wall and polemounting hardware.
TRENDnet TEW 738APBO 10 dBi Outdoor PoE Access Point - radio access point
Radio access point
External - outdoor
IEEE 802.11b, IEEE 802.11g, IEEE 802.11n
Frequency Band
2.4 GHz
Maximum number of configured SSIDs: 8
Pole mount, mounting brackets, waterproof RJ-45 plug
Power Over Ethernet (PoE) Supported
PoE
AC 120/230 V ( 50/60 Hz )
21.5 cm x 6.6 cm x 12.2 cm
800 g
3 years warranty
Radio access point
Ruggedized Design
Outdoor
21.5 cm
6.6 cm
12.2 cm
800 g
External
Wireless
Data Transfer Rate
300 Mbps
Line Coding Format
DQPSK, CCK, 64 QAM, BPSK, QPSK, 16 QAM
Spread Spectrum Method
OFDM, DSSS
Network / Transport Protocol
PPTP, L2TP, IPSec, PPPoE, DHCP, CSMA/CA, DDNS
Routing Protocol
OSPF, RIP-1, RIP-2, static IP routing
Remote Management Protocol
SNMP 1, Telnet, SNMP 3, SNMP 2c, HTTP, HTTPS, SSH
Frequency Band
2.4 GHz
Max Range Open Space
8 km
Selectable Channels Qty
13
Firewall protection, NAT support, remote reboot, VLAN support, repeating mode, MAC address filtering, VPN passthrough, Wireless Distribution System (WDS) support, IP address filtering, firmware upgradable, wall mountable, WISP mode, Wi-Fi Multimedia (WMM) support, event log, Quality of Service (QoS), virtual server support, Multiple SSID support, reset button, pole mountable, SNMP trap, Management Information Base (MIB), Class of Service (CoS), Type of Service (ToS), DiffServ Code Point (DSCP) support
Encryption Algorithm
WPA-PSK, WPA2-PSK, WEP
Authentication Method
RADIUS, Radio Service Set ID (SSID)
IEEE 802.3, IEEE 802.3u, IEEE 802.1D, IEEE 802.1Q, IEEE 802.1p, IEEE 802.11b, IEEE 802.11d, IEEE 802.11g, IEEE 802.1x, IEEE 802.11i, IEEE 802.11h, IEEE 802.11e, IEEE 802.11n, IEEE 802.11f
Aerial
Antenna
Internal
Directivity
Directional
Gain Level
10 dBi
1 x 100Base-TX (PoE) - RJ-45
FCC, IP67
PoE
External power adapter
22 Watt
Limited warranty - 3 years
-30 °C
60 °C
0 - 99% (non-condensing)
Scroll to top
