BT.com
Wishlist
TRENDnet TEW-737HRE N300 High Power Easy-N-Range Extender
TRENDnet TEW-737HRE N300 High Power...
£18.32
More than 50 in stock
£18.32
Add to wishlist
Delivery
Standard 3-5 working days
TRENDnet's N300 High Power Easy-N-Range Extender, model TEW-737HRE, offers extreme wireless coverage to eliminate existing wireless network dead spots. Setup takes minutes with no CD installation and it stays out of the way by plugging directly into an outlet. Simply press the Wi-Fi Protected Setup (WPS) button on your router, then on the TEW-737HRE and you're done--it's now extending your wireless network over a large area.
Ease of Use
Easy Setup
No CD installation--simply plug in the extender, scan for your wireless router, and connect
No Clutter
The compact form factor stays off the ground by plugging directly into an outlet
One Touch Connection
Securely extend your wireless network at the touch of the Wi-Fi Protected Setup (WPS) button
Encrypted Wireless
Supports the latest encryption and automatically adopts router settings
Extreme Coverage
High power amplifiers and multiple antenna technology offer extreme wireless coverage
N300 Wireless
Proven 300 Mbps Wireless N
Ethernet Port
Ethernet port for easy management access
Compatibility
Works with all Wireless N router brands
TRENDnet TEW 737HRE N300 High Power Easy-N-Range Extender - Wi-Fi range extender
External
Ethernet, Fast Ethernet, IEEE 802.11b, IEEE 802.11g, IEEE 802.11n
Frequency Band
2.4 GHz
AC 120/230 V ( 50/60 Hz )
5.6 cm x 6.7 cm x 4.5 cm
120 g
3 years warranty
5.6 cm
6.7 cm
4.5 cm
120 g
External
Wireless
Data Transfer Rate
300 Mbps
Line Coding Format
CCK, OFDM
Frequency Band
2.4 GHz
Status Indicators
Power, status, WPS
Auto-uplink (auto MDI/MDI-X), IPv6 support, MIMO technology, Wi-Fi Protected Setup (WPS), reset button
Encryption Algorithm
128-bit WEP, 64-bit WEP, WPA-PSK, WPA2-PSK
IEEE 802.3, IEEE 802.3u, IEEE 802.11b, IEEE 802.11g, IEEE 802.11n
Aerial
Gain Level
2 dBi
1 x management (100Base-TX) - RJ-45
ETSI, FCC
Internal power supply
6 Watt
Limited warranty - 3 years
0 - 95% (non-condensing)
Scroll to top
