BT.com
Wishlist
TRENDnet TEG-2248WS 48-Port 10/100 Mbps Web Smart  Switch
TRENDnet TEG-2248WS 48-Port 10/100...
£200.22
10 in stock
£200.22
Add to wishlist
Delivery
Standard 1-3 working days
TRENDnet's TEG-2248WS 52-port Gigabit Web-Based Smart Switch is the ideal switch for network segmenting. It has 48 10/100Mbps and 2 10/100/1000Mbps RJ45 ports with Auto-Sensing and Auto-MDIX feature for easy installation. This switch also has 2 Mini-GBIC ports that accept optional gigabit fiber modules for greater flexibility. The TEG-2248WS supports web browser configuration; Network Administrators can use web browsers to configure port speed, port-based VLAN, QoS, Trunking and also to monitor each port's status. TRENDnet's powerful and easy-to-use TEG-2248WS is designed to reduce unnecessary broadcast traffic and enhance network security.
TRENDnet TEG 2248WS - switch - 48 ports - Managed - rack-mountable
Switch - 48 ports - Managed
Enclosure Type
Rack-mountable 1U
Subtype
Fast Ethernet
Ports
48 x 10/100 + 2 x SFP + 2 x 10/100/1000
MAC Address Table Size
4K entries
Remote Management Protocol
HTTP
Flow control, trunking, VLAN support, store and forward
IEEE 802.3, IEEE 802.3u, IEEE 802.3z, IEEE 802.3ab, IEEE 802.1p, IEEE 802.3x
44 cm x 20 cm x 4.4 cm
2.6 kg
5 years warranty
Bundled Services
5 years warranty
Enclosure Type
Rack-mountable 1U
Subtype
Fast Ethernet
Ports
4K entries
HTTP
Flash Memory
1.5 MB
Status Indicators
Link activity, power, system
2 x 1000Base-T - RJ-45 , 48 x 100Base-TX - RJ-45 , 2 x SFP (mini-GBIC)
Internal power supply
26 Watt
Rack Mounting Kit
Included
FCC Class A certified, cUL, VCCI Class A ITE, IEC 60950, UL 60950
44 cm
20 cm
4.4 cm
2.6 kg
Limited warranty - 5 years
10 - 90%
Scroll to top
