BT.com
Wishlist
TRENDnet Powerline 500 AV Nano Adapter Kit
TRENDnet Powerline 500 AV Nano...
£30.67
Homeplug Pair - Perfect for Smart TV
Hurry, only 1 left in stock!
£30.67
Add to wishlist
Delivery
Standard 1-3 working days
Express Delivered on Tuesday
Express Delivery
  • 00 h
  • 00 m
  • 00 s
Kit - Contains 2 Units
The Powerline 500 AV nano adapter kit, model TPL-406E2K, uses any electrical outlet to create a secure high speed network. Connect the first adapter to your network and plug the second adapter into any outlet on your electrical system for instant high speed network access. The compact form factor saves space around crowded electrical outlets. This adapter automatically connects to other TRENDnet Powerline AV adapters with no installation required - TRENDnet recommends pressing the 'sync' button to automatically change default encryption keys.
Use up to 8 adapters to network devices in different rooms without running new cabling. Power save mode reduces power consumption by up to 80%. Quality of Service (QoS) technology prioritizes video, audio, and online gaming. LED displays convey device status for easy troubleshooting. Advanced 128-bit AES encryption secures your network. This adapter is ideal for use in buildings that interfere with wireless networking signals.
TRENDnet TPL-406E2K - bridge - wall-pluggable
Bridge
Enclosure Type
Wall-pluggable
Ethernet, Fast Ethernet, HomePlug AV (HPAV)
Data Transfer Rate
500 Mbps
Maximum of neighbouring networks : 4 , Nodes : 8
Network / Transport Protocol
CSMA/CA
Auto-uplink (auto MDI/MDI-X), IPv6 support, full duplex mode, Quality of Service (QoS), reset button
IEEE 802.3, IEEE 802.3u, IEEE 802.3x, HomePlug AV, IEEE 1901
AC 120/230 V ( 50/60 Hz )
5 cm x 7 cm x 4.3 cm
51 g
Microsoft Windows Vista (32/64 bits), Microsoft Windows 7 (32/64 bits), Microsoft Windows XP (32/64 bits)
3 years warranty
Bridge
Enclosure Type
Wall-pluggable
Wired
Data Transfer Rate
500 Mbps
CSMA/CA
Encryption Algorithm
128-bit AES
IEEE 802.3, IEEE 802.3u, IEEE 802.3x, HomePlug AV, IEEE 1901 , FCC, RoHS
Status Indicators
Link activity, power
Line Properties
Line Coding Format
8 QAM, 64 QAM, 256 QAM, BPSK, QPSK, OFDM , ROBO, 1024 QAM
1 x 10Base-T/100Base-TX - RJ-45
Internal power supply
2.2 Watt
TRENDnet 500Mbs Compact Powerline AV Adapter TPL-406E
2 x network cable - 1.5 m
Software Included
Drivers & Utilities
5 cm
7 cm
4.3 cm
51 g
3 years warranty
Service & Support Details
Limited warranty - 3 years
0 - 95% (non-condensing)
Other bundles
£30.67
C2G 2m Cat5e Cable with Homeplug
Save £2.00
£34.15
Customer reviews
Write review The opinions expressed in this reviews section are those of our customers and not of BT Shop. Nothing contained herein amends BT Shop’s terms and conditions.
5* great little gadgets
Reviewed by Alex on 10/06/2013
bought these to play with. have just connected my house pc to the router via these.
Wireless can occasionally cause minor issues
Just plugged and play. Full speed connection (only get 4 and a bit mb - but it's all there lol)
And both units are connected to cheap multi socket extensions.
Seem to run fairly cool as well.
Just ordered another couple of sets.
So far - seem pretty good :-)
5* Unbelievable Value
Reviewed by Billy on 08/04/2013
Seen these on Amazon for £35 or so and was close to buying them. How clever are these things? Bought a pair, plugged them in, didn't even have to use the sync button and my xbox live was connected in about 10 seconds!! How do you get internet through electricity?!
5* Amazing little devices
Reviewed by Kyle on 18/05/2013
My wireless devices all stopped working due to the large amount of walls degraded the signal to the point of it drops out. After buying these they were packed very nicely and it was very easy to set up. Didn't need to use the sync option they detected each other instantly and started working. I actually have one of these plugged into a block adapter and it is not interfering with the connection or speeds at all. And I have tested them in mains sockets on their own also.
Scroll to top
