BT.com
Wishlist
TRENDnet Network Cable Tester
£47.77
2 in stock
£47.77
Add to wishlist
Delivery
Standard 3-5 working days
The TC-NT2 is a convenient and comprehensive cable tester for network professionals. Its powerful and user-friendly features enable network installers to accurately check pin configurations of various voice and data communication cables. The TC-NT2 includes a master unit that transmits test signals to its corresponding remote terminator to verify cable reliability. It checks continuity and displays wiring configuration up to 300 meters of cable installation. With the unique feature of the audio tone generator, the TC-NT2 identifies and troubleshoots faulty cables to assure proper pin and wiring structure.
Tests Pin Configuration of 10/100/1000Base-T, 10Base-2 (coax), RJ-11/RJ-12/RJ-45, EIA/TIA-356A/568A/568B, and Token Ring Cables
Tests USB and IEEE 1394 cables with optional adapters
Built-in Tone Generator for tracing cable with standard Tone Probe (Not Included)
Tests the grounding on shielded (screened) cable
Verifies cable continuity, opens, shorts, and miswires
Tests cable up to 300 meters
Auto-Scan or Manual-Scan mode
Includes Deluxe Carrying Pouch, two RJ45-to-BNC Adapters, and RJ45 Patch Cable
1-year limited warranty
RoHS Compliant
TRENDnet TC-NT2 - network tester
Network tester
Tests, Tools and Measurements
Tests for shorts, tests for opens, tests for miswires, tests for continuity
11.5 cm x 6.8 cm x 2.7 cm
113 g
1 year
Network tester
Media
Copper
Carrying pouch, 2 x RJ-45 to BNC adapters, patch cable
Connectors
RJ-45
RoHS, FCC, PCT
Warranty
1 year
Voltage
9 V
Included Qty
1
Required Qty
1
11.5 cm
6.8 cm
2.7 cm
113 g
45 °C
Scroll to top
