BT.com
Wishlist
TRENDnet N300 2.4GHz High Power Outdoor PoE Access Point
TRENDnet N300 2.4GHz High Power...
£185.32
Hurry, only 3 left in stock!
£185.32
Add to wishlist
Delivery
Standard 1-3 working days
TRENDnet's N300 Outdoor PoE Access Point, model TEW-739APBO, provides blanket outdoor Wireless N300 connectivity for distances of up to 4 km (2.5 miles)*
A variety of installation scenarios are facilitated with Access Point (AP), Wireless Distribution System (WDS), Repeater, and CPE + AP modes. The rugged aluminum IP67 rated housing comes with wall and pole mounting hardware. Antennas, sold separately, are required in order to function*
Antennas
Antennas, sold separately, are required in order to function-- model TEW-AO57 or TEW-AO46S
Multi-Mode Support
Supports Access Point (AP), Wireless Distribution System (WDS), Repeater, and CPE + AP modes
N300 Wireless (2.4 GHz)
Compliant with 802.11n/g/b technology (2.4 GHz) with data rates up to 300 Mbps
Outdoor Rated
Durable aluminum enclosure with an IP67 outdoor weather rating
Distance Rating
Rated for distances of up to 4 km (2.5 miles)* (with TEW-AO57 antennas sold separately)
Power over Ethernet (PoE)
Comes with a proprietary PoE injector, so that it can connect a regular non-PoE switch
Logs
Real time logs and statistics help troubleshooting
Encrypted Wireless
Support for wireless encryption of up to WPA2
Multiple SSIDs
Create up to seven additional SSIDs
Compatibility
Compatible with legacy wireless devices
Mounting Hardware
Pole and wall mounting hardware included
TRENDnet TEW 739APBO N300 Outdoor PoE Access Point - radio access point
Radio access point
External - outdoor
IEEE 802.11b, IEEE 802.11g, IEEE 802.11n
Frequency Band
2.4 GHz
Maximum number of configured SSIDs: 8
Grounding kit, pole mount, mounting brackets, waterproof RJ-45 plug
Power Over Ethernet (PoE) Supported
PoE
DC 48 V
21.5 cm x 6.6 cm x 12.2 cm
800 g
3 years warranty
Radio access point
Ruggedized Design
Outdoor
21.5 cm
6.6 cm
12.2 cm
800 g
External
Wireless
Data Transfer Rate
300 Mbps
Line Coding Format
DQPSK, CCK, 64 QAM, BPSK, QPSK, 16 QAM
Spread Spectrum Method
OFDM, DSSS
Network / Transport Protocol
PPTP, L2TP, IPSec, PPPoE, DHCP, CSMA/CA
Routing Protocol
OSPF, RIP-1, RIP-2, static IP routing
Remote Management Protocol
SNMP 1, Telnet, SNMP 3, SNMP 2c, HTTP, HTTPS, SSH
Frequency Band
2.4 GHz
Max Range Open Space
4 km
Status Indicators
Power, WLAN, LAN
Power over Ethernet (PoE), remote reboot, repeating mode, MAC address filtering, VPN passthrough, Wireless Distribution System (WDS) support, IP address filtering, firmware upgradable, wall mountable, WISP mode, Wi-Fi Multimedia (WMM) support, Quality of Service (QoS), Multiple SSID support, reset button, pole mountable, weatherproof, dynamic IP mode, Direct Sequence Spread Spectrum (DSSS), Class of Service (CoS), Type of Service (ToS), DiffServ Code Point (DSCP) support
Encryption Algorithm
WPA-PSK, WPA2-PSK, WEP
Authentication Method
Radio Service Set ID (SSID)
IEEE 802.3, IEEE 802.3u, IEEE 802.1D, IEEE 802.1Q, IEEE 802.1p, IEEE 802.11b, IEEE 802.11d, IEEE 802.11g, IEEE 802.1x, IEEE 802.11i, IEEE 802.11h, IEEE 802.11e, IEEE 802.11n, IEEE 802.11f
1 x 100Base-TX (PoE) - RJ-45 , 2 x aerial - N connector
FCC, RoHS, WEEE, IP67
PoE
Power injector
DC 48 V
22 Watt
Limited warranty - 3 years
-30 °C
60 °C
0 - 99% (non-condensing)
Scroll to top
