BT.com
Wishlist
TRENDnet N150 Outdoor Poe Access Point
Delivery
Standard Due date unavailable
TRENDnet's N150 Wireless Outdoor PoE Access Point, model TEW- 715APO, provides high speed building-to-building networking with its built in dual polarization directional 8dBi antenna. Install an omnidirectional antenna (with a N-Type connector), such as TRENDnet's TEW-AO08O to provide blanket outdoor wireless coverage over a large area. A range of applications are facilitated with Access Point, Wireless Client, WDS, Bridge, CPE, and Repeater mode support.
A durable IP55 rated outdoor enclosure protects the device from inclement weather. Power for this unit is supplied by an included PoE injector, resulting in equipment and installation cost savings. Additional features include SNMP (v2c, v3), Spanning Tree, real time network activity tables, WPA / WPA2 encryption, MAC address filters, 16 virtual AP profiles, 802.1Q, 802.1X, mounting hardware, and GPS coordinate support.
1 x 10/100 Mbps Auto-MDIX PoE LAN port
1 x PoE injector
1 x Reset button
1 x Reverse N-type connector for optional antenna installation (omni-directional or directional)
LED indicators:
LAN
WLAN: Red (good), Yellow (better), Green (best)
Internal high powered 8 dBi dual polarization directional antenna
IP55 weather rated housing
High speed data rates of up to 150 Mbps based on IEEE 802.11n technology
Compliant with IEEE 802.11b/g standards
Supports Access Point (AP), Wireless Distribution System (WDS) / Bridge, Customer Premises Equipment (CPE), Wireless Client, and AP + Repeater modes
Multiple SSID or Virtual Access Points (up to 16) with Layer 2 VLAN wireless client isolation
Access restriction with MAC filtering
Real time network activity tables
802.1Q support
Universal Plug and Play (UPnP) for auto discovery and support for device configuration of Internet applications
Complete wireless security with WPA / WPA2-RADIUS, WPA / WPA2-PSK, and WEP
Wi-Fi Multimedia (WMM) Quality of Service (QoS) data prioritization
Easy setup via Web browser using Internet Explorer 6.0 or above, Firefox 2.0 or above, Chrome, Opera, and Safari
Supports SNMP (v2c and v3), Telnet, SSH, and HTTP / HTTPS management
Pole mounting hardware
Electrical ground cable
3-year limited warranty
Speed and Distance References
Please note that the following information concerning potential connection distances and speeds are for reference only. They are referenced from clear line of sight installations with no other potential sources of signal degradation. Every installation environment is unique. TRENDnet is not responsible for performance metrics that may vary from those referenced below.
When networked to the same unit, this unit is rated for connecting over clear line-of-sight. Please note that these values are provided as a general guide to overall potential performance, and not as an indication of performance for your installation scenario.
TRENDnet TEW 715APO N150 Wireless Outdoor PoE Access Point - radio access point
Radio access point
External
IEEE 802.11b, IEEE 802.11g, IEEE 802.11n
Frequency Band
2.4 GHz
Grounding kit
Power Over Ethernet (PoE) Supported
PoE
6.4 cm x 22.8 cm x 6.1 cm
340 g
3 years warranty
Radio access point
Built-in Devices
GPS
6.4 cm
22.8 cm
6.1 cm
340 g
External
Wireless
Data Transfer Rate
150 Mbps
Line Coding Format
DBPSK, DQPSK, CCK, BPSK, QPSK, OFDM
Spread Spectrum Method
OFDM
Remote Management Protocol
Telnet, SNMP 3, SNMP 2c, HTTP, HTTPS, SSH
Frequency Band
2.4 GHz
Max Range Open Space
10 km
Selectable Channels Qty
13
Status Indicators
Power, WLAN, LAN
Power over Ethernet (PoE), auto-uplink (auto MDI/MDI-X), repeating mode, MAC address filtering, Wireless Distribution System (WDS) support, Wi-Fi Multimedia (WMM) support, Quality of Service (QoS), RADIUS support, Multiple SSID support, reset button, pole mountable
Encryption Algorithm
128-bit WEP, 64-bit WEP, 152-bit WEP, WPA-PSK, WPA2-PSK
Authentication Method
RADIUS, Radio Service Set ID (SSID)
IEEE 802.3u, IEEE 802.1Q, IEEE 802.11b, IEEE 802.11g, IEEE 802.1x, IEEE 802.11n, UPnP
Aerial
Antenna
Internal
Antenna Qty
1
Directivity
Directional
Gain Level
8 dBi
1 x 100Base-TX (PoE) - RJ-45 , 1 x aerial
Grounding kit
Mounting Kit
Included
ETSI, FCC, RoHS, WEEE, IP55
PoE
Power injector - external
12 Watt
Limited warranty - 3 years
-20 °C
70 °C
0 - 95% (non-condensing)
Scroll to top
